TIRES HELP!!
Old Mar 12, 2006 | 01:21 AM
MO PAR's Avatar
MO PAR
Default TIRES HELP!!
i need opinions does anyone think i will be able to clear 37-14 16 swampers on 16x12 inch rims. on a ram 1500 reg cab with 3" of susp and 3" of body lift. was running 315-75-16 bfg at ko before and they only scrubbed on near max turns.
Old Mar 12, 2006 | 03:23 AM
Redone4x4's Avatar
Redone4x4
Default RE: TIRES HELP!!
Ive heard 35's (or 315/75/16) is the most you can go. im curious also, i have an ext. cab with the same lifts you have. i think you would be pushing it, expecially if you rub already with 315's though.
Old Mar 12, 2006 | 03:28 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Sorry for stealing the thread but how does your truck sound with the flowmaster exhaust and whath muffler did you get?
Old Mar 13, 2006 | 03:51 AM
Chopper1's Avatar
Chopper1
They might fit, but don't plan on turning the wheel. I have the same lift set up with 35 X 12.5 tires and 10" wide rims. They fit good and do not hit in the corners. Too close to get larger though...
