Installed my Throttle Body This morning.
Holley makes a billet 52mm for the Dodge Magnum motors, it will actually outflow any modded stock tb as with a billet they can taper the bore more without running out of bore wall as you do with a bored stock tb. I believe it flows around 100 cfm more than a comparably bored stock unit. I have one on my truck,nice workmanship on them also.
ORIGINAL: Dodgeramman
19 ft lbs from Hayes repair manual section 4a-1
ORIGINAL: Ram_sport96
I looked all over my owners manual and the internet and I couldn't find the torque specs for the TB bolts so I just tightened down really carefully. .
This one is supposed to be flowing 760 CFM...
The sensors came on the unit but one of them was the wrong plug type.... maybe it was for a newer model than mine... I just swaped over my old one...
ORIGINAL: steve00ram360
the stock TB's are holley's... the 52mm fastmans are the modded ones, the one on e-bay looks un-modded.
[IMG]local://upfiles/1508/D1275008074D4431BBEC50BB2755BA27.jpg[/IMG]
The one in the pix in above posts is just a modified stock tb, the Holley billet 52mm tb is 1 piece solid block of machined aluminum that flows around 850 to 900 cfm.Billet pix below:
[IMG][/IMG]
[IMG]local://upfiles/23203/DF4C3D032A844E2A90CAFD4AADA30DB6.jpg[/IMG]
[IMG][/IMG]
