1998 1500 5.2L... 2 or 3 O2 sensors???
Old Mar 14, 2006 | 06:34 PM
radwebster's Avatar
radwebster
Default 1998 1500 5.2L... 2 or 3 O2 sensors???
i've been looking online, and i just called napa, and everything is showing that i should have 3 O2 sensors in my truck. but, i had replaced the catalytic converter not too long ago, and i only saw two under there. i see one right in the cat where the two down pipes meet, and there is one between the cat and the muffler. i pulled codes on my truck, and it shows a few for the bank 1 sensor 1 spot. is there an O2 sensor that i am missing?? thanks
Old Mar 14, 2006 | 07:52 PM
Ram_Sport's Avatar
Ram_Sport
Default RE: 1998 1500 5.2L... 2 or 3 O2 sensors???
i have the same deal, only ones i know of are one b4 and one after cat, i think we are right 2
Old Mar 14, 2006 | 10:15 PM
radwebster's Avatar
radwebster
so would the one in the O2 sensor be "bank 1 sensor 1"?
Old Mar 15, 2006 | 01:00 AM
Ram_Sport's Avatar
Ram_Sport
possibly.
what are your symptoms, mine just went nuts flooded then ran like ****, turned out to be sensor 2, i think its the one in the catalytic converter for you.
Old Mar 15, 2006 | 03:53 AM
radwebster's Avatar
radwebster
my truck has been killing fuel since i changed the catalytic converter. i think one of the O2 sensors was damaged either from the clogged cat or maybe from the install. i'm getting like 5-6 mpg's. in park, at about 800-1000 rpms it puts out a little black smoke. it smells like fuel. i've checked the codes, a few of them were for the O2 sensors (3 for the bank 1 sensor 1 unit).
oddly enough, even with all these too-much-fuel syptoms, i still got a code for 'bank 1 too lean'
i erased all the codes, and i got 'bank 1 sensor 1 O2 sensor low volts' again, so it looks like that sensor is bad.
Old Mar 15, 2006 | 04:03 AM
ryans590's Avatar
ryans590
'bank 1 too lean' is a bad ingector i think
'bank 1 sensor 1 is the o2 before the cat (you do only have 2 o2's)
id change out both o2s at the same time and see if that fixes your problem if not then the next step would be to check your ingectors but they could be out because of the o2s
Old Mar 15, 2006 | 09:24 AM
Ram_Sport's Avatar
Ram_Sport
ya the low volts what screwed me over, get a new one if it throws that i would say, also replace the other one like ryan said, not a bad idea i didnt cause i didnt have the money all at once, maybe some other day , hopefully its not your injectors
Old Mar 18, 2006 | 09:01 PM
97BurlyRam1500's Avatar
97BurlyRam1500
They only have the 2 O2 sensors one before the cat and one after to check efficiency of the cat. The 02 sensor will also make your truck run lean. if it is not reading right it can send the engine into LIMP mode and run rich. If ur running lean check fuel pressure and fuel VOLUME, that one must be stressed the pump might be giving you pressure but not enough volume to the injectors.
