Newbieeee =) help please
Old Mar 21, 2006 | 09:29 PM
d0dg3_m4n's Avatar
d0dg3_m4n
Default Newbieeee =) help please
I just bought a 94' Ram 1500 sLt and there is a brake problem im trying to find the solution to it
but i dont kno where to look up... so i found this forum askin for some help from ppl who have
problems also =) so if you can please help me i'd really appreciate it =)
thanks all,
SAAAAAAAATTTTTTTTTTTEEEEEEEEEEEEEEBBBBBBBBBBBBBBBA AAAAAAAAAAANNNNNNNNn
P.S. If u CAn'T DodGE it ------------------RAM IT !
Old Mar 21, 2006 | 09:42 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Newbieeee =) help please
Helps if you tell us what the brake problem is.
Old Mar 21, 2006 | 09:46 PM
d0dg3_m4n's Avatar
d0dg3_m4n
brakes gave out and when i push down on the brake pedal it doesn't want to stop
feels like there are no brakes... i push down the pedal all the way down and nothing....
i hope that is enough info =)
Old Mar 21, 2006 | 10:32 PM
Ramsrush's Avatar
Ramsrush
Sounds like fluid leak.
Old Mar 21, 2006 | 10:35 PM
d0dg3_m4n's Avatar
d0dg3_m4n
no leak because I checked the brake fluid and there is still half way and no sign of leaks
Ty tho!
Any one else have any ideas???
thanks
Old Mar 21, 2006 | 10:39 PM
Tani1500's Avatar
Tani1500
check the master cylindar to see if theres any fluid in there. they have a problem with the brake lines rusting and cracking right behind the gas tank. look by there and see if you can see fluid
Old Mar 21, 2006 | 10:41 PM
d0dg3_m4n's Avatar
d0dg3_m4n
ty i will have to check that out And ill see if that does anything I apricaite ur time
And how can i fix that problem if that is the problem??
Old Mar 22, 2006 | 12:53 AM
Socha_62's Avatar
Socha_62
Air get in there somehow? could always give them a bleed. If that doesn't do it I'd check your vacuum line going into the MC. And lastly check the MC/get a new one. They're easy to take apart and replace the seals though.
Old Mar 22, 2006 | 01:33 AM
d0dg3_m4n's Avatar
d0dg3_m4n
thanks ill try that i apriaciate all ur help guys
THANKS!
Old Mar 22, 2006 | 01:43 PM
steve05ram360's Avatar
steve05ram360
the master cylinder has gone bad. swap it out, check for any rusted brake lines and replace them while your at it. you will need to bleed the brakes real good to make sure you get all the air out.
