Old Aug 5, 2015, 01:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Detailing and Cleaning
Print Wikipost
cloudy headlights
Old Oct 22, 2006 | 11:00 PM
  #21
shott8283's Avatar
shott8283
Default RE: cloudy headlights
ive used that stuff from permatex.. still a WEEEE bit hazy but it sure cleaned up that brake parts cleaner i sprayed on the headlight on accident.. stuff works really well.. and for 15 bux a kit .. cant beat it!! one kit per headlight i would suggest.. the sandpaper isnt if best quality..
also.. use a block or some kind of implement to apply good pressure while wetsanding.. helps it go a bit faster..
edit::: damnit.. SSOO didnt see the date of the original post.. oh well
Old Oct 22, 2006 | 11:02 PM
  #22
JarheadX's Avatar
JarheadX
nicola, stop yellin at us
Old Oct 23, 2006 | 01:08 AM
  #23
nhlbill's Avatar
nhlbill
3M Rubbing compound is what I used. I was too scared to use it with anything mechanical for fear that I would somehow screw them up. So I just used the rubbing compound by hand and a lot of elbow grease.
Mine were really bad before I used the rubbing compound and now they look new. Take your time and the end result will be worth it or you could go buy new ones. A little effort and a bottle of rubbing compound will work, or spend alot of money on new ones ..........your choice.
Old Oct 23, 2006 | 04:31 AM
  #24
johnjokela's Avatar
johnjokela
i saw on ebay they had halo projector lights for 01 ram one piece , i dunno will this work , is it a rip off or a good upgrade? like the look but if its a PITA to install then maybe nevermind then, lol, thanks
Old Oct 23, 2006 | 08:38 AM
  #25
BeachCrawler's Avatar
BeachCrawler
My '94 Grand Cherokee had the same problem. They were so cloudy I could not see the bulbs inside. I used Meguiars PlastXâ„¢. It was less than $7 at Advance Auto. I applied the polish and then I used a hand grinder (Dremel type) with a polishing tip to buff it. But a drill or any high polisher with a soft pad will do. I did small 3" or 4" patches at a time. Once it was clean and dry I applied a good car polish to protect it from UV ray damage and they sparkled like diamonds.
Old Oct 23, 2006 | 08:57 AM
  #26
HankL's Avatar
HankL
Whitening toothpaste has very fine aluminum oxide polishing compound in it.
I have used toothpaste on a green Scotch Brite pad by hand,
followed by toothpaste on a sponge by hand.
This works slowly on getting the yellow off the headlights, but you have less chance of messing up by gouging too deep with rubbing compound.
Old Oct 23, 2006 | 12:32 PM
  #27
frey51's Avatar
frey51
I was checking out ebay and found stock headlights for $65 plus like $20'ish for shipping. Not a bad deal if you ask me. You should check it out.
Fry
Old Oct 23, 2006 | 07:13 PM
  #28
DieselDemon's Avatar
DieselDemon
NOVUS products has a 3 step polish. Work EXTREMELY well with a mini buffer. Sears, Dremmel, etc.
Good luck.
Old Oct 23, 2006 | 08:11 PM
  #29
steve05ram360's Avatar
steve05ram360
I used the Maguires stuff on my wifes corolla and it helped out alot, not as good as i'd like it, maybe I should try one of the methods you guys use...
Old Oct 24, 2006 | 12:41 AM
  #30
stovepipe's Avatar
stovepipe
check out MIRROR GLAZE BY MEGUIARS or NOVUS acrylic polish. im a acrylic tech so i use these products. the novus is hard to come by butt it works the best
