!!Help!! Engine just shuts down
Old Mar 24, 2006 | 12:35 AM
venado's Avatar
venado
Default !!Help!! Engine just shuts down
guys i really need help
tuesday y replaced original coil for an accel mopar & a pacesetter air fx intake air filter and some 8.2 thunderbolt spark plug cables such as cap and rotor
spark plugs are also new.
my truck worked perfectly but today when i was dirving back home the engine just shutted off for 3 times
as soon as it shutted off i started again and ran perfectly until it shutted off again which could be the problem.
i all ready checked for some loosen cables and hoses that go to the sensors and all of them seem to be O.k
any recomendations ?
Old Mar 24, 2006 | 01:34 AM
20dodgeram01's Avatar
20dodgeram01
Default RE: !!Help!! Engine just shuts down
did you re-wire all your plug wires back to exactly where they were suppose to go? maybe acouple could be touching and interfering with eachother.. i dunno im just guessing
Old Mar 24, 2006 | 01:41 AM
ryans590's Avatar
ryans590
not trying to be an a$$ but dod you get the right parts
Old Mar 24, 2006 | 01:43 AM
20dodgeram01
probally not even a problem with the wires or anything.. could be something completely diffrence.. when my old truck did that it was the ignition module that went bad
Old Mar 24, 2006 | 02:07 AM
Chopper1's Avatar
Chopper1
rotor button or cap loose or moving?
Old Mar 24, 2006 | 02:49 AM
shott8283's Avatar
shott8283
coil wiring loose or shorting
was it a direct replacement where the connector just cliped in or did you have to do some wiring yourself?
Old Mar 24, 2006 | 03:04 AM
venado's Avatar
venado
the conector just clipped
forgot to say before installing all that stuff cleaned the motor with degreaser and pressure washer
thats why i checked all hoses just in case that some one was loose due to the water pressure
Old Mar 24, 2006 | 03:08 AM
shott8283's Avatar
shott8283
lol last time i washed the motor down it rain like CRAP for like 5 miles...bucked like i was down 4 pistons and the tranny was dragin ... you mita got some water somewhere its not sapoda be
Old Mar 24, 2006 | 12:28 PM
jrmcx's Avatar
jrmcx
A single or even multiple plug or wires won't shut the engine down. Did it throw any codes? I think it's wet component or coil problem. If problem persists put the old coil back in, and see if that fixes the problem.
Old Mar 24, 2006 | 01:00 PM
venado's Avatar
venado
i just got to work driving 25 miles
and had no problem,engine ran smooth and perfect
what i did last night i disconected the battery just to avoid those strange
computer memory effects "hope this works"
