oil pressure
Old Mar 25, 2006 | 06:47 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default oil pressure
99 with a 5.2 What should the oil pressure be when the truck is at idle?
Old Mar 25, 2006 | 10:49 AM
MikeNAmyS's Avatar
MikeNAmyS
Default RE: oil pressure
It will vary with oil weight.
I run 10W-40 year round with Lucas oil stabilizer and after warmed up it holds 40psi at idle.
It shouldn't drop below 25psi with higher milage engines.
Keep in mind mine only has 30,000 miles.
Old Mar 25, 2006 | 07:53 PM
Zeppelinrocks
mine is right below 40 so im good thanks for the help
