Making 4x2 into 4x4?
Old Mar 25, 2006 | 02:07 PM
JustinJohnson86's Avatar
JustinJohnson86
Default Making 4x2 into 4x4?
Ok, I've heard of a 4x4 conversion for Chevys (myself owning a chevy in the past) and heard that doing so will make the ride really uncomfortable...
My question is, is it possible to convert my dodge 4x2 into a 4x4? I know it sounds dumb, but i could only afford the 4x2 at the time and am itching for a 4wd...
Any problems in doing this (ex: rough *** ride, parts not fitting properly)? Would i need to change the transmission or just add a transfer case? Shorten driveshaft? Anyone ever done this?
Oh yeah, heres the information about my truck from the build sheet that was sent to me:
*R1 - Premium Cloth 40/20/40 Bench Seat
-C3 - Mist Gray
ADAP - Light Group
AJKP - Convenience Group
APAS - Monotone Paint
ASPP - SLT Decor Group
A05P - 5.2L Engine(ELF)/4Sp Auto Trans(DGT)
BAUS - 117 Amp Alternator
BCES - 600 Amp Maintenance Free Battery
BGJS - Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS - 11x2 Rear Drum Brakes
CBEP - 40/20/40 Split Bench Seat
CGDS - Front Height Adjust Shoulder Belts
CGWS - Next Generation Front Air Bags**
CGZS - Passenger Air Bag On/Off Switch
CHEP - Deluxe Headliner
CKEP - Front Seat Area Carpet
CLAP - Front Floor Mats
CSPS - Passenger Assist Handle
CSRP - Passenger Assist Handles
CUDP - Mini Overhead Console
DGB - All 4-Speed Automatic Transmissions
DGTS - 4-Spd. Automatic 46RE Transmission
DHAP - Lock-Up Torque Converter
DMDP - 3.55 Axle Ratio
DRBP - Corporate 9.25 LD Rear Axle
EAAC - All Engines
EAGC - All Gas Engine
ELF - 5.2L V8 MPI Engine
GACS - Tinted Glass Windows
GJDS - Rear Fixed Window
GNAS - Rear View Day/Night Mirror
GNMP - Passenger Side Sun Visor w/Mirror
GTSP - Power Heated Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
HAAP - Air Conditioning
HGAP - Hood Insulation
HGBS - Dash Liner Insulation
JAYS - Instrument Cluster w/Tach
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJS - 12V Auxiliary Power Outlet
JPBP - Power Locks
JPDP - Power Windows, Driver One-Touch
KTXP - STRIPE/BADGE/MOLDING/COLOR
K1XP - STRIPE/BADGE/MOLDING/COLOR
K17P - STRIPE/BADGE/MOLDING
Old Mar 25, 2006 | 02:30 PM
livinginh's Avatar
livinginh
Default RE: Making 4x2 into 4x4?
Easiest way is to buy a 4x4 and trade you 2wd in,, second easiest is to find a rolled 4x4, (make sure the frame is not tweaked) and put your good body over on it. 3rd is the hardest, but yes it can be done wont change the ride no more then what a stock dodge 4x4 is. You will still need to find a donor truck, prefered close to your year. But most 2wd bodies and frames are set up from the factory to be either a 2wd or 4wd. Saves money for them. They will be cut out holes in all the right places, your factory 2wd frame will have the places to bolt on the 4X4 suspention. YES there will be welding and cuting involved. There will be wiring to be done also.
In formost, this is not and easy task, it can be done. So choice is up to you if you want to undertake it and deal with the time your truck will be down.
Old Mar 25, 2006 | 02:40 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I agree, sell your truck and buy a 4x4.
Old Mar 25, 2006 | 07:23 PM
Socha_62's Avatar
Socha_62
Anything is possible, and if your one of those people who love to tinker, fab stuff up, and think "outside" the box, it'd be a really fun project to do!
Sure it'd be a PITA and take alot of time and brainstorming, but it would be cool to do!
The others might be right though, could be much cheaper to actually sell and buy a 4x4.
Off the top of my head here what I can think of, but there would be alot more stuff.
Axle complete with control arms, coils, coil towers, trac bar, ect.
Steering box
Front drive shaft
T-case
Shorter rear drive shaft
Vacuum system for front axle (or just posi-loc it)
PCM from 4x4 same year as yours
Thats just stuff I thought of off the top of my head, would be fun though!!!
Old Mar 25, 2006 | 07:29 PM
badram1500's Avatar
badram1500
would be very tough but can be done. Don't know how your insurance guy would like it. May need to be DOT'ed to even get plates after the conversion.
Old Mar 25, 2006 | 09:38 PM
JustinJohnson86
Thanks for the input, this is exactly the type response i was looking for...
I think I'll stick with the 4x2, still got 11k in payments =(
I'll eventually have a 4x4
