Vacuum problem under load
Old Mar 30, 2006 | 05:58 PM
BradBeyer's Avatar
BradBeyer
Default Vacuum problem under load
I am sure this has been talked about but I must be searching for the wrong terms. So I apologize early.
My Specs.
1997 Dodge Ram 1500 2wd
5.2L
extended cab
When I am going up a hill or put a little bit of a load on my truck my vent blower stops and once the engine is not under the load anymore ithe vent blower works again. I am sure it is a vacuum leak somewhere but I have ran mostly all new hose trying to find it. Does anyone have this problem? Has anyone fixed this problem.
Old Mar 30, 2006 | 06:08 PM
mopowar's Avatar
mopowar
Default RE: Vacuum problem under load
What makes you think it's a vacuum leak?
Old Mar 30, 2006 | 06:21 PM
BradBeyer's Avatar
BradBeyer
Because the cruise does not work under a load either....it will not kick down it will just lose speed until it is not under a load (going up a hill) and then go back to where it was set.
Old Mar 30, 2006 | 08:26 PM
MikeNAmyS's Avatar
MikeNAmyS
I had a similar problem.
The vent would switch up to the defroster when under a load and then you'd leave off and it would go back to the vent.
I never did figure it out, but you could hear a vacumn hiss under the dash.
It may be the switch itself.
Old Mar 30, 2006 | 08:32 PM
Silver_Dodge's Avatar
Silver_Dodge
Ya sounds like a vacuum problem. Problem is finding the leak.
There is a check valve right off of the intake manifold and one right off of the firewall. Start with replacing those as they are know to go bad (http://dodgeram.info/tsb/1996/24-01-96a.htm). They are cheap to replace. If that doesn't do it, you will need to find the leak somewhere else in the system, which can be tricky.
Old Mar 30, 2006 | 11:20 PM
cnewt15's Avatar
cnewt15
I had the exact same problem on my Ram. I found a break in the vacuum line that runs up under the battery tray to the cruise servo, which is why the cruise wouldnt work. There was an elbow then it made a sharp turn onto the servo, it broke there. I hope this helps you out, may not be the same break, but I bet it is the same hose.
Old Mar 31, 2006 | 11:34 AM
BradBeyer's Avatar
BradBeyer
Ok it does switch to the defroster under load. Silver_Dodge you have hit the nail on the head. I was pulling my valve cover off this weekend and broke one of those hoses. I could not find where it went to under the dash so put a tight rubber vacuum hose over it...or what I thought was tight. I am going to try to zip tie it tighter to make sure it is not leaking there either. cnewt15 I already replaced that vacuum line a while back ago and check it quite regulary.
So I am safe to say that it is a vacuum leak somewhere correct?
Old Mar 31, 2006 | 05:24 PM
BradBeyer's Avatar
BradBeyer
Well the zip tie idea did not work....any other ideas?
Old Apr 1, 2006 | 02:48 PM
Chopper1's Avatar
Chopper1
ORIGINAL: BradBeyer
Might need to find where this went. If it was hooked to something before and now isn't, there might be another part of it's destination bleeding off vaccuum from another source.
