Is there something under my plastic bedliner?
Old Mar 31, 2006 | 10:43 AM
52b3b108's Avatar
52b3b108
Default Is there something under my plastic bedliner?
I bought a 2000 1500 that has a plastic bedliner in it. On each side of the tailgate there are small bars welded for tie-downs and the bedliner is cut out to access them. Is there the same type of thing in the front of the box that I can't see because of the bedliner? If so, where are they so I can cut out the bedliner if possible?
Old Mar 31, 2006 | 11:03 AM
JustinJohnson86's Avatar
JustinJohnson86
Default RE: Is there something under my plastic bedliner?
I would look at my truck right now, but since its raining outside, and i'm half dressed... Sorry...
Umm your best bet would be to just pull the bedliner, not hard at all, should be secured in the bed with just a couple of snaps until the rail... If not its got railcaps on it. just take those off and then the bedliner..
To save you time just pull the front part of the bedliner off and bend forward a little. Take a flashlight and peek in there.
Old Mar 31, 2006 | 11:37 AM
Chopper1's Avatar
Chopper1
On my 97 the front has a hole on each side in the floor of the bedliner. There are holes in the bed with hooks/crossbar to hook a strap to, right at the front edge about 5" from the side. They have rubber plugs to cap off too. They are a pain unless you use a very small hook. Thought about getting a couple like in the rear and adding them to the front.
Old Mar 31, 2006 | 07:25 PM
Dodgeramman's Avatar
Dodgeramman
I will post a pic after batteries are charged. Once you see whats under a plastric bedliner you will want it off!!!!
Old Mar 31, 2006 | 09:28 PM
52b3b108's Avatar
52b3b108
Is it going to be nasty under there? I think I can see marks where a topper has been on there so maybe it isn't too bad underneath. I'll cross my fingers.
Old Mar 31, 2006 | 09:34 PM
shott8283's Avatar
shott8283
its called rust it it will detroy your truck..spray it or take it off and refinsh the bed ,, possibly get some more years out of it... what the hell good is a truckwith a bed that cant hold anything b/c its falling apart?
Old Apr 1, 2006 | 11:34 AM
52b3b108's Avatar
52b3b108
Like I said earlier, I think the truck had a topper on it before I bought it. If I buy a tonneau cover it shouldn't be a problem, right?
Old Apr 1, 2006 | 01:52 PM
CopperDesigno's Avatar
CopperDesigno
ORIGINAL: shott8283
I had a beat up Mazda pickup, I threw a cinder block in the bed and it poke throught the bed floor [:@] So I fiberglassed the bed floor and about 3 inches up each side with the heavy duty fiberglass. Then I used Duponts cheap roll on bed liner. The bed never looked so good and it took a beating for over 2 years until the head gasket let go and I had a white steaming mess drivning down the highway The dupont stuff doesn't like heat I found out, it will peel and flake.
Old Apr 1, 2006 | 01:59 PM
ebxgsxr's Avatar
ebxgsxr
yeah, i was thinking about taking off my bed liner too. anyone in the MD area want it?
Old Apr 1, 2006 | 02:26 PM
Chopper1's Avatar
Chopper1
Just bite the bullet and remove the screws and pull it up for a look. If there are any problems you can take care of them. Locate and or add tie downs. If there isn't anyproblems, put the screws back in and keep on trucking. Think positive......
