need help fast re: timing marks on case
Old Apr 2, 2006 | 06:18 PM
tjtim's Avatar
tjtim
Default need help fast re: timing marks on case
Okay, need a fast answer trying to set my basic fuel sync, my case reads 5 befor and 5 after top dead center, manual says to set at top dead center, then go to 17.5 degrees after or line up at the v-8 mark----where is the v-8 mark located, can't use scale to 17.5 degrees as it only goes to 5 degrees after top dead center-----anyone know where the v-8 mark is, I looked everywhere and can't seem to find anything, need to do this today...
Thanks in advance..........
Tim
Old Apr 2, 2006 | 07:47 PM
mopowar's Avatar
mopowar
Default RE: need help fast re: timing marks on case
Why do you need to set your fuel sync? Normally fuel sync is set by the PCM based on input from the cam position sensor and a variety of other sensors.
Old Apr 2, 2006 | 09:58 PM
tjtim's Avatar
tjtim
I had to reset my fuel sync because I pulled the distributor and the engine was turned over a few times when out, reset the engine on the #1 compression stroke to top dead center. I did find the V-8 mark finally after cleaning up the vibration dampener---its on the dampener itself not on the case, anyhow set it to 17.5 degrees after top dead center on the V-8 mark, back probed the distibuter harness conector possitive to the yellow wire, negative to the center black wire then using a dc volt meter you turn the distributor to switch between the zero and 5 volt mark, you set it closest to either side of zero or 5 volts, this sets basic fuel sync, enough to drive it til it can be put onto a computer and set as the facotry service manual states using a diagnostic scan tool............ basically its a hillbilly/redneck setting to get by on, but in no means is it perfect..........
