Leaking SON OF A @$#*&
Old Apr 3, 2006 | 12:27 AM
Dodgeramman's Avatar
Dodgeramman
Default Leaking SON OF A @$#*&
Okay walked out the house and what do I see a puddle, not oil, brake fluid, nor coolant! So I grab the creeper and roll under there line myself up and look up. F&*k my power steering box is leaking. Here I am looking for a thread for a repair and I find one, damn it is not the right one. It seams they are for the pitman arm seal mine is leaking by the input shaft. Has anyone had this problem and fixed it or do I start looking for a steering box???
Old Apr 3, 2006 | 12:31 AM
shnormo's Avatar
shnormo
Default RE: Leaking SON OF A @$#*&
Start looking for a steering box.
Old Apr 3, 2006 | 12:36 AM
CopperDesigno's Avatar
CopperDesigno
You can buy a rebuild kit for them, replacing/rebuild depends on the mileage and how loose the steering is. Pavement sucks.com has a write up on it I think.
My old one was leaking from the pitman arm, but the new box leaks from the gasket between top plate and the body.
The POINT is don't buy a LARES steering box, it leaks form day one. It has a lifetime warrenty, but who wants to do a job twice.
Old Apr 3, 2006 | 12:38 AM
Big_N_Bad's Avatar
Big_N_Bad
i am leaking right now. I have to buy i new one. I just awesome buy the best one out there since if you buy a oem one again it is still going to leak. I need to replace both the steering boxes and the actual pump. Your lucky. thanks
BNB
Old Apr 3, 2006 | 12:57 AM
shott8283's Avatar
shott8283
scott...that sux dude... check the local scrap yards for a new steerin box i guess... or that rebuild kit..heard from the guys at ps.com that its a good one and not hard to do... other then that...i havnt had to monkey with my box except tighting the adjuster screw up
Old Apr 3, 2006 | 01:16 AM
Socha_62's Avatar
Socha_62
Mine just started leaking really bad from the input too
Old Apr 3, 2006 | 02:39 PM
ljpierce_ely's Avatar
ljpierce_ely
Now that I'm seeing all these messages about a leaking steering box, I am going to have to take a look at mine.
For something like this, usually to save money for more important MODS, I will go to:
http://www.car-part.com
Don't buy the first one you see nor the cheapest. Search through the results. I usually go towards the middle of the search or at least one page before the cheapest ones.
Just chiming in.
Old Apr 3, 2006 | 02:56 PM
GOD RAM IT's Avatar
GOD RAM IT
I went with a Lares 3500 steering box. It last a year or so then I replace it.
If I look back and did it over again I would get a PSC box (the extreme duty one). It is the same price as the stock 1500 one (maybe 50-60 bucks more).
Old Apr 3, 2006 | 07:33 PM
Socha_62's Avatar
Socha_62
I'm debating to rebuild mine or just replace it cause the steering is pretty sloppy. You know of any sites to buy those boxes Ram It?
Old Apr 3, 2006 | 07:39 PM
Socha_62's Avatar
Socha_62
Wait a min, you mean Poisen Spyder's don't ya by PSC
