A-piller gauges??
Old Apr 5, 2006 | 12:31 PM
dodge_boy31807's Avatar
dodge_boy31807
Default RE: A-piller gauges??
Well what type gauges should I put in? I'm not sure what types to put in and what kind as of exhaust temp and things. Anyone have any types?
Old Apr 5, 2006 | 12:35 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
go ricer and put your gauges as a non-digital clock, an outside temperature gauge, etc etc.
Old Apr 6, 2006 | 03:43 PM
dodge_boy31807
So you are saying that I should just put something in there to take up space?? I don't really know any other types of gauges to use on a gas truck.
Old Apr 6, 2006 | 03:57 PM
Silver_Dodge's Avatar
Silver_Dodge
ORIGINAL: The Burning Rom
....Mechanical Trans Temp: Because I use my truck primarily for towing/hauling. Electric trans temp gauges don't go high enough.....
My electric trans temp gauge goes to 250. If I ever see temps that high, I am in serious trouble. Why would you need higher then that?
All,
Autometer makes several different pod options for our Rams. single (15204), double (17202, 15203), and triple (17201, 17203) a-pillar pods, single steering coumn pod (15012, which I have), and triple dash mounted pod (15002).
http://www.autometer.com/cat_mounts....l=62&gw=0&pg=2
http://www.autometer.com/cat_mounts....l=62&gw=0&pg=3
http://www.autometer.com/cat_mounts....l=62&gw=0&pg=4
Old Apr 6, 2006 | 04:24 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: Silver_Dodge
It's not uncommon for the autos in the 2nd gens to get up there in temps when towing a heavy load. 220...230...even 240 [>:] I don't really want to look at a pegged (or almost pegged) gauge when towing The mechanical gauge runs to 280, so it should be real easy to tell if there's a problem. Plus I like the fact that the mechanical gauge is full sweep.
IIRC, the factory gauges in the Silverados run even higher than 280 [>:] though I've never seen it get near it when plowing snow or towing a loaded dump trailer.
Old Apr 6, 2006 | 04:25 PM
muddy_blue_dodge
just want to make sure yall know i was completely kiddin about teh ricer thing...................
Old Apr 6, 2006 | 04:43 PM
Silver_Dodge
Your trans temp light will come on before you ever hit 250. Auto meter makes both full and half sweep electical gauges too.
Old Apr 6, 2006 | 07:26 PM
The Burning Rom
I know they do, but not in the series that I want They don't have a full sweep electrical trans temp gauge. Only 100-250 half sweep.
Old Apr 6, 2006 | 07:41 PM
Silver_Dodge
Ya, I noticed that afer I posted. No full sweep electrical trans temp guage. [:@]
Where you planning on putting the sending unit?
Old Apr 6, 2006 | 08:27 PM
The Burning Rom
The deep cast aluminum pan from Mopar has a fitting in the side for the sending unit. I plan on putting them on both at the same time. I had planned on doing it this summer, but with the price of premium pushing $3.00 a gallon the truck might not get driven or modded as much as I'd like [:'(] I might spend the $$$ on a cam for my Grand Prix instead. I can still get 26-28mpg city/highway with that...cammed...and running premium, compared to the truck's 13.5mpg UNLOADED with very little city driving [>:]
