rear axle question
Old Apr 4, 2006 | 12:01 PM
BradBeyer's Avatar
BradBeyer
Default rear axle question
I have a 1997 Dodge Ram 1500 2wd with a 318. I want to know which rams came with 410 gears in the rear axle and if it would fit under my ram.
Thanks
Brad
Old Apr 4, 2006 | 12:09 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: rear axle question
They all could've come with 4.10s...if you ordered the 4.10 option
The ONLY 2nd gen 1/2 tons that had standard 4.10s were the OFF-ROAD edition Rams that were built in 2000 & 2001. They used the Chrysler 9.25 rear axle, which was the ONLY rear axle available for the 1/2 tons.
I'm not sure why you're looking to swap axles, but if it's just for the gear ratio, you're better off just upgrading the rear-end that you have now with a new gear set
Old Apr 4, 2006 | 12:15 PM
BradBeyer's Avatar
BradBeyer
I figured it would be cheaper and faster to switch out axles then to change gears. I have 3.55's in it now (that is stock) and I have Nitto Terra Grapler LT295/75 16 tires on it. I am looking to more of a stock gear ratio with this tire.
Old Apr 4, 2006 | 12:32 PM
The Burning Rom
It would be faster, but probably not much cheaper. Good used axles tend to be a bit pricey, even the 9.25. [>:] Plus, if it were me, I'd rather have a new set of gears for my money, than a used axle/differential/gear set that I don't know the history of. That's just my thought on it though.
