Help ram 2500 v10.
Old Apr 4, 2006 | 06:15 PM
Rebeliouspunk4's Avatar
Rebeliouspunk4
Default Help ram 2500 v10.
im looking at starting to mod my truck out. i only got about a grand and i know i need new tires. but after that im not sure what i should put into it. im thinking a kanN filter to bust intake. also maybe a body lift or a suspention lift later down the road. any input on tire size or what kinds. or any input on the best things to add on first. thanks for anything
Old Apr 4, 2006 | 07:28 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Help ram 2500 v10.
What year is your truck?
K&N FIPK Intake...MUCH better than the drop-in filter.
Fastman TB www.thefastman.com
A set of headers...Gibsons are good
Cat-back (or at least replace the stock muffler which doesn't flow). Again, gibson is a good choice.
Mopar Performance PCM (You MUST run premium fuel with this)
Mopar Performance Plug Wires (Also make sure the plug wires are re-routed so that 7 and 5 are NOT touching each other)
Champion Truck Plugs
Depending on the year of your truck, you may want to do the wheel cylinder upgrade that I did. It NOTICEABLY improves your braking! And for less than $50 [8D]
Stay away from the body lifts Not sure why you'd need a suspension lift either. It's a 3/4 ton...so it already sits pretty high.
Old Apr 5, 2006 | 03:28 AM
Rebeliouspunk4
its a 98. and i think ima get a body lift because i wanna set some 36 under it unless they will fit without it,. not sure. ima find that out tommorow. so thanks for the input the brakes thing i think ima do my brakres arnt workn to good
Old Apr 5, 2006 | 04:05 AM
Spike7ss's Avatar
Spike7ss
you can fit a 305/70R16 under with minor rubbing. With 2 inch (or 3) you can run 35s.
Old Apr 5, 2006 | 03:05 PM
Rebeliouspunk4
thanks any comments on the all terrain t/a's bfgoodrich?
Old Apr 6, 2006 | 01:20 AM
Spike7ss's Avatar
Spike7ss
One of my girlfreinds ran 33 A/T BFGs, and hated them, no traction what so ever on her bronco. They are a highway only tire in my opinion
