318 injector differ from 360?
Old Apr 14, 2006 | 12:18 AM
dflyboy's Avatar
dflyboy
Default 318 injector differ from 360?
I am just wondering if the injectors are different on the 360 as compared to the 318 and with my engine swap if i NEEDED to changed them out too?
Old Apr 14, 2006 | 09:16 AM
HankL's Avatar
HankL
Default RE: 318 injector differ from 360?
From the DML and Shane M:
begin quote:
"I read the following from the Q&A section of the April 2001 Mopar
Performance News:
Q(5) I'm working on a fuel-injected combination and my dyno program
shows I could benefit from more injector delivery. What can you tell me
about flow rates of the injectors in your catalog? Also, if you have
the factory injector rates would be very helpful.
A(5) You should step up the injectors in something like only 25 percent
increments. The production V-8 is 24 - the MPP package is 30! Remember
that you must change the computer if you change the injectors; at the
least, it must be reprogrammed with the new injector values. Injector
rates are not as easy as one might think, but they go something like
this:
Engine Years Flow rate in lb/hr
Neon ( All) 23.9
2.5 Magnum 91-95 17.4
2.5 Magnum 96-01 23.2
4.0 Jeep 91-95 21.4 (Equivalent to Lucas 5207013 )
4.0 Jeep 96-01 23.2 (Equivalent to Lucas 5208005 )
5.2 Magnum 92-95 18.2
5.2 Magnum 96-01 23.2(Seimens/Chrysler P/N 53030778)
5.9 Magnum 93-95 24.5
5.9 Magnum 96-01 23.2 (Seimens/Chrysler P/N 53030778)
---end quote---
Note that about 1996,
when the engine PCM computers went to the OBD-II standard,
all the Dodge fuel injectors went to a 'common calibration' of 23.2 lb/hour.
If you have a modified 1996+ Magnum engine and you feel you need to 'bump up'
the fuel injectors just a bit, the model year 1993-1995 5.9V8 fuel injectors
are about 6% larger at 24.5 versus 23.2, and Neon injectors are 3% bigger.
Fuel Pump/Regulators inside the tank have changed pressures over the years too.
Old Apr 14, 2006 | 08:08 PM
dflyboy's Avatar
dflyboy
thaks for the answer, I appreciate it.
