stock to 35s
Old Apr 20, 2006 | 10:22 PM
AR4CE's Avatar
AR4CE
Default stock to 35s
Apologies if its been covered, but I need 4 characters to do a search.
I'm goig from stock to 35s (2000 ram 1500 4x4, 5.2 auto).
I do a lot (A LOT!) of highway driving-- how much is my tranny/speed/mileage going to take a hit?
Thanks yall
Old Apr 20, 2006 | 10:31 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default RE: stock to 35s
Are you planning on lifting it or already have a lift on to fit those 35's?
Old Apr 20, 2006 | 10:56 PM
Socha_62's Avatar
Socha_62
You shouldn't take much of a hit if your smart and regear to 4.56
Old Apr 20, 2006 | 11:47 PM
AR4CE's Avatar
AR4CE
I'm trying to avoid the regear cost as long as possible.
How bad is it going to be w/ stock gearing?
(I have a BDS 5" coming in to clear it)
Old Apr 20, 2006 | 11:50 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
your really gonna want to regear.... i assume your still on stock tire size? when i switched to 33s.... only 33s!! i could tell a significant differance, so i can only imagine 35s. (although i am assuming you have 3.55s..... if you have the 4.10s from the factory then i guess it wouldnt be such a noticible difference)
Old Apr 20, 2006 | 11:56 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: AR4CE
What IS your stock gearing?
Old Apr 21, 2006 | 12:23 AM
AR4CE's Avatar
AR4CE
I'm pretty sure its 3.55 (new truck to me)
Old Apr 21, 2006 | 01:08 AM
Socha_62's Avatar
Socha_62
3.55's with 35s is gonna make a HUGE diffrence in power and mpg. I know its alot but think about how long it will take to pay itself off when your getting say 15mpg instead of 10mpg.
Old Apr 21, 2006 | 11:45 AM
Chopper1's Avatar
Chopper1
I can tell you first hand. It will hurt badly without a gear change. The power drop is significant.
My speedo is about 10% off. At 70 I'm really around 77 acording to a couple of friends stock rides. So when calculating gas mileage add 10% to the mileage. Better MPG than I thought though.
I cannot use O/D unless perfectly flat ground at 70, or 75, acording to my speedo. I mean perfectly flat. So I run the highway with the O/D off at 26 to 3000 RPM's in order to be able to get out of my own way. Around town it's not that big of a deal, since I'm not trying to race anyone. Not to mention that the stress on our trans. with the tires and 3.55 gear is not good when the trans is trying to push and the O/D will kick up and down. Then you get tired of no power and just leave the O/D off.
Me I got a set of 4.56's and really need to harrass my buddy to get them installed so I can drive normal again.
If you do much driving on 55 to 70 MPH roads it will hurt. If you never leave town and don't want to run anyone you"ll be OK
Old Apr 21, 2006 | 12:24 PM
muddy_blue_dodge
for 35s are 4.56s suggested? i thought it was 4.10s for 35s......
