MODS!!
Old Apr 21, 2006 | 04:02 PM
dodge_boy31807's Avatar
dodge_boy31807
Default MODS!!
Alright since I made a post about the K&N FIPK, I wouldn't mind knowing, is there anything I should buy as a mod frist before I buy the air intake?? What mods are there out there to buy? I know there is the programmer and that is about all I know. I've put a 180 degree t-stat in and it does make a diffrence, I found a better throttle responce out of it, but I am like most people and I need more. What should I go with and where to buy. Also I was wondering about horsepower chips, if anyone makes them for a 95 5.2 and what to go with power wise, and how much one runs? You all have been a lot of help for me in the past and I have to say it, I just want a little more out of my truck. What should I do?????
Old Apr 21, 2006 | 05:00 PM
steve05ram360's Avatar
steve05ram360
Default RE: MODS!!
there are a ton of mods out there that you can do...
Air intake
programmer or custom flash on your PCM
exuast Dual or single
180 t-stat
better heads R/T's or the Heavy duties...
cam you name it
roller rockers many to choose from
M1 intake manifold
or Mod your intake manifold
50/52mm throttle body fastman...
check out www.krcperformance.com, make sure you have something to wipe the drool off...
Old Apr 21, 2006 | 05:43 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default RE: MODS!!
the programmer your talkin about (hypertech) you cant use. you have OBD I (95) so it wont work on your truck.
im in the same situation...
Old Apr 21, 2006 | 06:19 PM
steve05ram360
Default RE: MODS!!
good catch, I didnt see that it was a '95, pcm flash is the best bet.
Old Apr 22, 2006 | 12:09 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: MODS!!
ORIGINAL: steve00ram360
It's the only option....other than the Mopar Performance PCM, which is basically a PCM flash.
The jet chips have been proven not to work [>:]
Old Apr 22, 2006 | 01:33 AM
shott8283's Avatar
shott8283
Default RE: MODS!!
jet chips have been proven the rob your horsepower and in RM Indys case lost some secs on his ET's
flash that beast sumpin fearce!
Old Apr 22, 2006 | 01:37 AM
muddy_blue_dodge
Default RE: MODS!!
how much does a flash cost in comparison to the mopar performance PCM?
Old Apr 22, 2006 | 01:41 AM
shott8283's Avatar
shott8283
Default RE: MODS!!
i think the company is called B&G .. not sure on the price... but ive heard its better then the mopar pcm b/c they actually remove the tq manegment that hinders performance
search for B&G ... IIRC thats the name
Old Apr 22, 2006 | 01:52 AM
jnellydodge's Avatar
jnellydodge
Default RE: MODS!!
Air intake
180 t-stat
cam you name it
M1 intake manifold
On your white truck steve, after all your mods what were you running for Horsepower and Torque numbers ?????
