code 0442
Old Apr 22, 2006 | 12:19 AM
jalapeenoz's Avatar
jalapeenoz
Default code 0442
Couple of days ago I got a cel with a trouble code of 0442. That is a leak in the evap system. I found a hose going into what I believe is the leak detection pump (looking at the 01 service manual) that was partially cracked and fixed it. After resetting the pcm I got the code again. Someone suggested replacing the gas cap which I did with a Mopar cap and reset the pcm. Yesterday the light came on again with the same code showing up again. Has anyone had any experience with this? I don't know much about the evap system. I'm looking for things to check to take care of this without having to take it to a garage or dealer.
Any help would be greatly appreciated.
Old Apr 22, 2006 | 12:36 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: code 0442
Check the lines running to the EVAP canister. It should be mounted on the frame rail under the passenger side of the cab.
Old Apr 22, 2006 | 03:28 PM
jalapeenoz's Avatar
jalapeenoz
I followed the lines going back to the canister and found no leaks, cracks, or holes. Could the canister, or leak detection pump be bad? Are there any filters that need to be changed?
Old Apr 22, 2006 | 03:38 PM
20dodgeram01's Avatar
20dodgeram01
i have that same problem with my truck.. the evap codes.. i beleive it might be the canaster they go bad a lot
Old Apr 22, 2006 | 05:00 PM
The Burning Rom
ORIGINAL: jalapeenoz
There are no filters. The LDP or the canister could be bad. If a large amount of liquid fuel makes it's way into the canister, it can cause it to fail. I'm guessing you also checked the canister itself for any damage?
I can't say which would be bad. You can tell if the canister has fuel in it by unbolting it and shaking it.
IIRC, the LDP is a common issue for the Ram as well. [>:]
Old Apr 22, 2006 | 06:41 PM
jalapeenoz's Avatar
jalapeenoz
I did not see any damage to the canister, but I didnt unbolt it and shake it. I guess I can try that next. Will it hurt the truck any or affect performance and/or fuel economy if I just leave it the way it is?
