Need Royal Purple info
Old Apr 22, 2006 | 09:08 PM
sephirothq's Avatar
sephirothq
Default Need Royal Purple info
Looking for information on what i should run for fluids
I have a 1995 1500 4x4 with a 5.2 auto and 3.55 gears
What should i use for
tranny (auto)
transfer case
front rear
rear
engine
Let me know what is recommended
thanks
Dave
Old Apr 23, 2006 | 03:46 AM
jon v's Avatar
jon v
Default RE: Need Royal Purple info
Engine - SJ, GF-1, or GF-2, above 0 F 10W-30 preferred (API certified)
Auto Trans- Chrysler ATF+3 (ATF+4 replaces it)(not Dexron III, there is a difference)
Transfer case- depends on the model: NP205= GL-5 90W above -10 F, NP 207, NP 208, NP 231, NP 241, NV 231, NV 241, NV 242, ATF DexronIII or Chrysler ATF +3
Differential - GL-5, above -10 F 90W, 80W-90, 85W-140, above 90 F 140W (don't forget the friction modifier if you have a limited slip)
Always go by what the owners manual recommends
