voltage regulator
Old Apr 22, 2006 | 10:17 PM
akdennis1's Avatar
akdennis1
Default voltage regulator
OK all you "Gurus", I need some help. I guess the voltage reg is in the computer for a 95 ram 3500. Its the weekend, no computers to be found here in hickville USA. I've heard a voltage regulator can be installed to bypass the computer, but I need some help. HOW WHAT WHERE WHEN & HOW do I do this, please help as I need to be back to work Monday & it's 400 miles from here. Thanks, You guys are my only hope.
dennis
Old Apr 23, 2006 | 01:38 AM
shott8283's Avatar
shott8283
Default RE: voltage regulator
well whats the problem first... how do you know the VR is bad? if the VR is bad .. you might have other issues since is integrated into the PCM.. you can get an exteranal universal VR .. a standard VR is a rectifier and regulator and reducer.. the three R's an Alt produces AC current and the VR rectifies it into DC, it regulates it by restricting the Amperage that the alt can or does produce so it doesnt overload the system, and it reduces the volatage to 14 volts,,, standard voltage that all 12V systems run on..
my question is how do you know your VR is bad? ive NEVER heard JUST the VR going on these trucks/pcm's if your having electrical problems please explain whats going on..
as far as the universal aftermarket VR .. its possbile to install one.. best bet is to go to autozone or something of the sort and ask them what they got as far as VR's.
