Easiest way to jack up rear of truck and put jack stands under it?
Old Apr 27, 2006 | 10:52 PM
bobem12's Avatar
bobem12
Default Easiest way to jack up rear of truck and put jack stands under it?
This may be a dumb question but I am changing my rear shocks soon and I need to know the easiest way to lift the rear of the truck to get it on jackstands. Where exactly should I position the jack in order to raise it and where should I place the jack stands. I've never raised the rear of the truck before so I'm looking for pointers. Truck is a '98 1500 4x4. Thanks.
Old Apr 27, 2006 | 10:59 PM
Socha_62's Avatar
Socha_62
Default RE: Easiest way to jack up rear of truck and put jack stands under it?
Any vehicle with a solid rear (and front for that matter) should be jacked up right on the diffrencial houseing. All there is to it
Old Apr 27, 2006 | 11:18 PM
bobem12's Avatar
bobem12
thanks for the reply. So just right under the pumpkin huh? I thought about that but I didn't want to break anything so I figured I would ask.
Old Apr 27, 2006 | 11:44 PM
GOD RAM IT's Avatar
GOD RAM IT
why are you jacking the truck to replace shocks?
Old Apr 28, 2006 | 12:01 AM
bobem12's Avatar
bobem12
I wasn't aware that you could change them without jacking it up. I have a Haynes manual and it tells me to jack the truck up and place it on jack stands but if I could change the shocks with the truck on the ground that would be better.
Old Apr 28, 2006 | 12:06 AM
Ram_Sport's Avatar
Ram_Sport
what he said, i didnt have to jack to do shocks, but when u take shox off, bounce the vehicle, you will get a kick out of how bouncy it is, i know i did..
Old Apr 28, 2006 | 01:08 AM
crazy1snow's Avatar
crazy1snow
undamped spring... hmm yeah it's gonna BOUNCE LIKE HELL!!!!!!!
you do know that is why we have shocks right? ok sorry i've been in tooooooo many dynamics classes dealing with springs..
Old Apr 28, 2006 | 01:14 AM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: crazy1snow
In layman's terms....to absorb energy....to slow the truck down when it hits a bump
They are not load bearing (the leaf springs are for that). They're just there to dampen the ride.
Spike7ss's Avatar
Spike7ss
Putting jack stands under your truck to do shocks gives you a little bit more room to work under there, otherwise,its sorta a waste of time, and its safer not to have your truck on jack stands.
Just remember to remove the spare tire to get to the upper left rear shock bolt
I did mine on my hoist with the truck sky high in the air, had to lower the truck, rip the jack kit apart from under the rear seat, lift the truck back up, then carry on
Old Apr 28, 2006 | 02:27 AM
Socha_62's Avatar
Socha_62
More random information!! Correct, shocks don't support any weight! But what other deviece does?
And answer is....STRUTS!!!
Lots of people don;t actually know that Shocks support no weight while struts are beefier cause they do support weight!
