aftermarket coolant temp gauge?
Old Apr 29, 2006 | 11:37 PM
Redone4x4's Avatar
Redone4x4
Default aftermarket coolant temp gauge?
i searched and found nothing except trans temp gauges, so here it is. still not having any luck with the stock gauge, and now i probably wont trust it if it did work again. has anyone installed an aftermarket one? i dont need anything fancy, just something accurate. if so, were/ how did you tie it in to the cooling system?
Old Apr 29, 2006 | 11:55 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: aftermarket coolant temp gauge?
http://www.egauges.com/vdo_mult3.asp...Z-Series&Cart=
Water temp gauge
I'd go with an electrical one. Slightly less accurate than a mechanical, but there's no unecessessary running of hot fluids into the engine bay.
Old Apr 30, 2006 | 12:50 AM
Redone4x4's Avatar
Redone4x4
yeah, summit racing has a nice digital electric one. its red to match the dash and truck too. do i need the sending unit, or does the gauge use the stock one? i just put a new one in.
