Idle Conrol Valve
Old May 2, 2006 | 09:39 AM
hilliad's Avatar
hilliad
Default Idle Conrol Valve
Anyone had problems with the Idle Control Valve?
Old May 2, 2006 | 11:24 AM
ASH's Avatar
ASH
Default RE: Idle Conrol Valve
There's been a lot of discussion on that. Do a search using "IAC" and you should get a lot of threads to look at.
Old May 2, 2006 | 12:59 PM
Socha_62's Avatar
Socha_62
They usually get gunked with stuff, mine did a while back. Simply take the TB off and all the conectors and ge some carb/TB cleaner. It helped me ALOT
Old May 2, 2006 | 01:52 PM
hilliad's Avatar
hilliad
thanks for the info
Old May 2, 2006 | 02:11 PM
steve05ram360's Avatar
steve05ram360
they also will start to get sticky. when they do you can try lubricating the shaft on the motor but that may not work for long... a new one is about $65 bux at napa.
Old May 2, 2006 | 04:46 PM
Racinfan83's Avatar
Racinfan83
Go here https://dodgeforum.com/m_455618/tm.htm for more info. Don't just have the dealer fix it - they wanted $185 to replace the IAC - I fixed it with half a can of carb cleaner and 15 minutes of my time.......
