Setting timing
Setting timing
How do i set the timing for a 95 5.2? The timing advance is computer controlled but how to a remove the advance from the computer to get the proper timing set up? what should the timing be without the advance? which cylinder is #1 is is the first on teh drivers or passengers side? not too familiar with these engines and trying to learn?
RE: Setting timing
#1 is on the driver's side. You can get aftermarket controllers to advance and retard timing or (best IMO) get a custom flash. Timing will change based on engine temp., air temp., tps voltage, etc.
Programmers and chips (Superchips, Hypertech) will also advance your timing.
