New lift....now problems
Old May 3, 2006 | 08:34 PM
AR4CE's Avatar
AR4CE
Default New lift....now problems
This could be coincidence, but I'll give the whole story:
-2000 ram 1500 4x4 5.2L, 210k mi
-new 5" BDS lift,
-35" MTs
-Put a can of seafoam through it
-Drove home today and it started shuddering, and threw a misfire code.
- Changed plugs and wires, started right up.
-Starts and idles fine, but under any load will rev up and then die. (put it in D, R, etc - or even rev it up)
-Searching has revealed possible crank position sensor, or dirty TB
Thought I'd get some input first before I spend any more money
Old May 4, 2006 | 01:48 AM
Tani1500's Avatar
Tani1500
Default RE: New lift....now problems
it could be the crank sensor. it located on the right hand side on top of the bell housing. or it is on mine anyway. kind of a pinta to get to. i would also try cleaning the TB and all that. check your crank sensor quick though because if its cracked and it breaks off your totally screwed so i hope you have a AAA card.
Old May 4, 2006 | 04:29 AM
Socha_62's Avatar
Socha_62
Check your cat too. It can idle fine and be ok at lower RPM and any high RPM and it will kill it or cause it to run like ****.
Old May 6, 2006 | 12:58 PM
badram1500's Avatar
badram1500
I agree with the cat idea. Had a ram do the same thing to me more than once.
