MALF INJ #9 on V-10
Old May 5, 2006 | 03:59 AM
Spike7ss's Avatar
Spike7ss
Default MALF INJ #9 on V-10
Hey, tossed in a couple injectors on my truck today, had one dead one and one other one that hasnt been replaced, and after its all said and done, Im getting the Check Engine light.
So toss in the scanner, pops up with MALF INJ #9 code, I think it was P0209.
Any hints as to what I should hit with a hammer first?
I cleared the memory and it went away for about 50 KMs, and now the light is back on and is running like it was.
Old May 5, 2006 | 09:46 AM
shott8283's Avatar
shott8283
Default RE: MALF INJ #9 on V-10
swap injector #9 with a known good, or brand new one. clear the codes and run it. if it follows that injector is bad, if it stays the wiring or other problems could be causing it
Old May 5, 2006 | 03:30 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: shott8283
I agree. That's the first thing I'd try!
Old May 11, 2006 | 12:28 AM
SST_Ram's Avatar
SST_Ram
When your done swapping injectors, and still having a problem. Try thoroughly cleaning all your ground connections on your engine. I posted a similar problem with my 5.9. Check out my post "Stalling problem" for some ideas.....Checkout www.alldata.com for wire testing info, pinout data, etc for a subscription fee.. Its worth it...Good luck.
Old May 11, 2006 | 02:04 AM
Spike7ss's Avatar
Spike7ss
pulled the plug off,and cleaned up the connectors really good. Cleared the memory, and so far havent had any problems
