IAT Relocation??
Old May 6, 2006 | 04:32 PM
jscherencel's Avatar
jscherencel
Default IAT Relocation??
I was thinking about moving my IAT to my CAI K&N so I can get a more cooler reading at the sensor. Then plug the hole in the intake. What type of performance can I expect? I know I'll be getting a "honest" reading. But I don't know what will happen when i do that. I really don't want to drill a hole in CAI and then find out that it does nothing. So, any information would be helpfull.
Old May 6, 2006 | 08:44 PM
Socha_62's Avatar
Socha_62
Default RE: IAT Relocation??
From what others have said, you will notive a slight power improvement, but your gonna loose MPG
Old May 8, 2006 | 01:20 AM
jscherencel
How much performance am I looking at? A couple of horses or double digits? I'm still unsure if its worth it or not.
Old May 8, 2006 | 01:54 AM
Silver_Dodge's Avatar
Silver_Dodge
You may see some performance gains at first, but the IAT is only one sensor in the entire system. It will cause you to run rich at first, giving you more power, but as soon as your pre and or post cat sensors detect that you are rich, they will lean the system back out anyway, so any performance that you might have felt at first will go away.
Also, several people who tried it had the check engine light come on because it made things too rich. It's not going to be a quick/cheap HP giver by no means, if that is what you thought. Probably give you more headaches then it would be worth in my opinion.
Old May 8, 2006 | 01:40 PM
mojo's Avatar
mojo
I have tried moving it and I have tried the cheezy shoving the resistor trick in the IAT and at first there was HP improvement but after the ECM figured out what was going on it over corrected the problem and all my efforts were lost. I have a 98' QuadCab with the 5.9 as well. I have done just about the same mods as you have except for the Hypertech Programer. If I am not mistaken that should have reprogramed your ECM to adjust your IAT for the new Air and Fuel Curves. By hte way how is does the Hypertech work for you? I was thinking of doing that upgrade but I was also thinking of just punching it out to 392 ci. What do you think? Thanks
Old May 8, 2006 | 11:38 PM
jscherencel
Well from what you guys have said ... I won't be doing it.
I love my Hypertech. As soon as I had it installed it, I noticed a difference. The new program really woke up my truck after I did all of those mods. I would HIGHly recommend it to anyone with a Ram that has been modified a little. Punching it out would definately put you further up the HP scale faster. I think it all comes down to how much money you have and what you are going to use it for. Work, commuter, off roader, tow'r, or toy.
My only problem now is I have a bad plenum and it's knocking. So I need to fix it. I am wanting to get a Hughes modded Intake Manifold (instead of fixing the plenum), Fastman 52 throttle body, and Edlebrock heads. Then I'll be done with the engine. There will pry be a few odds and ends I'll put into it but that's what I'm saving up for. Buy it and do it all at once. Maybe an electric fan after all is said and done.
jscherencel
