lets play name that sensor/bracket
Old May 6, 2006 | 06:33 PM
Tani1500's Avatar
Tani1500
Default RE: lets play name that sensor/bracket
you should see the sensor next to the distributer. i think thats it anyway. hope that helps somewhat good luck
[IMG]local://upfiles/15914/7B30CDB6F1FF4EB189BEFB8E0173D0D1.jpg[/IMG]
[IMG]local://upfiles/15914/C5C4DE918EA54A9F87612046F7CDD253.jpg[/IMG]
Old May 6, 2006 | 06:58 PM
allamericanjeep's Avatar
allamericanjeep
u guys are the best. . . .
Old May 6, 2006 | 07:20 PM
allamericanjeep
does anyone know if the heater hoses are interchangeable?
can either one go to either part of the block? Its just going to a small core right? does flow direction matter?
also how does the heater hose attach to the water pump? i just have a hole there, is there a fitting?
Old May 6, 2006 | 08:41 PM
Socha_62's Avatar
Socha_62
The one on the third pic just holds your 2 trans lines that go to the cooler. Its not very nessacary expecially if your gonna bend your own trans lines.
You have to buy a small metal pipe that has an o-ring on it and just pops into the water pump. $10 at any parts store, just had to get one the other day.
Old May 6, 2006 | 08:42 PM
crazy1snow's Avatar
crazy1snow
gotta love disassembling something then putting it back together and having a left over bolt. now where the hell did that bolt come from?
my roommate has a bucket full of bolts and stuff that he has no idea where they came off. really amusing to me. oh and he leaves bolts floating around in his engine bay of his dd... rattle rattle rattle as it turns... that's really funny.
Old May 6, 2006 | 09:08 PM
allamericanjeep
haha ya. its fun though. . .
anyone know about those hoses? does it matter which one goes in which opening?
thanks!
Chris
Old May 6, 2006 | 10:21 PM
livinginh's Avatar
livinginh
It will be easy to tell, one hose is bigger then the other. The heater hose closest to the water pump area usually will be the pushing hose, or output I guess you could say, the other one will be intake or return, I dont think it matters to much, but you dont want the heater water to have to push up through the heater core, you want it to flow down through it. Unless of course yours has the hoses side by side, then I dont think it really matters much.
