lift questions
Old May 8, 2006 | 01:10 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default lift questions
ok guys so im set on a 3 inch suspension lift (coil spacers, AALs) because i dont want to have to start changing geometrical stuff in the suspension and all the EXTRA stuff that comes with a 3+ inch lift. My question is would a 2 inch body lift on top of a 3 inch suspension cause any problems? what would go along with doing that? anything special other than brake line extensions etc etc?
Old May 8, 2006 | 07:50 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: lift questions
If you buy a bodylift kit it will come with everything you will need.
If you have a auto tranny you'll have to add to the shift linkage. But if its a standard than you wont have to do anything.
the brake lines wont need to be lengthened by doing a body lift
