before i buy...transmission q's
Old May 10, 2006 | 12:34 AM
Marneaus's Avatar
Marneaus
Default before i buy...transmission q's
Hey folks, im mihty new here, but not new to dodges.
I am going to be purchasing a 2nd gen ram in the near future, most likely a 1500 4x4. Having only owned dakota's in the past (1997 and 2004), both of which were 5 speed manual, I have no knowledge of the automatic transmission found in nearly all of these rams.
I am aware that the ram auto transmissions are notorious for failure, and this is what I need info on. I have searched the forums and have only really found information regarding specific problems, not a general overview.
I am going to try my hardest to get a 5 speed, but i know they are pretty hard to come by, especially in 4x4. So, in the event that i cannot find one, i need some information.
So, please, if you will, tell me of the problems with these transmissions. I have read people saying that they go out at 10,000, 40,000, 80,000 and people who have gone through 3 at 100,000 miles. What i'd like to know is some sort of failure rate. obviously i'm not going to know if the truck i buy is going to last 5k or 50k, but any general failure rate would be helpful. How about things to look for? is towing a contributing factor? does transmission maintnance (fluids, etc) have a large effect? is anything over a certian milage bad, or could it be a good indicator of a strong, long lasting tranny? Should i buy one that has already had the transmisison replaced?
Any information you guys could offer would be great. I really look forward to getting a ram, and i think these forum will be a great resource.
Thanks for your help
Old May 10, 2006 | 12:41 AM
DPR250R's Avatar
DPR250R
Default RE: before i buy...transmission q's
I bought my Ram with about 70,000 miles on it in 2002. I worked at a Chrysler dealer at the time and looked up the warranty history. Work was done to the valve body... not sure what though. As far as I know it is the original trans.
Since I have owned it I have changed the tranny fluid and filter twice.
I have not had a tranny problem and the truck now has about 150,000 miles on it.
I do not tow much and do not consider myself an abusive driver. I do not beat on it... I think I drive pretty normal. I do not off-road with it either.
I have replaced the fuel pump, right front axle seal and u joint, water pump and battery.
Sehr916's Avatar
Sehr916
I have 105,000 on the tranny that game with the truck and i havent really taken care of it either
Old May 10, 2006 | 01:13 AM
The Burning Rom's Avatar
The Burning Rom
As far as I know, the trans in my V10 is original. It has 144,000 miles on it. The torque converter seal is leaking, but that's it. I'll be fixing that this summer....along with installing a Mopar cast aluminum deep transmission pan...Amsoil Synthetic ATF...and an autometer transmission temperature gauge. That should keep mine going for a while, until I can afford a DTT built transmission.
It's all about maitenance on these trucks. If you do the right upgrades (Synthetic fluid, deep pan, larger cooler, regular fluid/filter changes), the transmission can last quite a long time.
Old May 10, 2006 | 02:42 AM
bamory's Avatar
bamory
180,000 on my original tranny, oil changed regular, not abused but used. Its the luck of the draw, I see alot of posts from people saying they have tranny problems, and also alot of the same people posting saying how they can do smokey burnouts...etc etc, or go 4 wheeling extensively.....so its just who, how, why, when it comes to these tranny's
Old May 10, 2006 | 02:57 AM
nmason's Avatar
nmason
ive got a 96 V6 with the auto. has 180000km on it. just had the fluid changed and the bands adjusted last week. first servicing ever for it. has always worked great.
Old May 10, 2006 | 03:54 AM
radwebster's Avatar
radwebster
160,000+ on mine, original trans as far as i know. works perfectly...i'm not terribly abusive on it, but i don't baby it either...go wheeling all the time, had the whole thing in water, mud...
Old May 10, 2006 | 07:15 AM
Marneaus's Avatar
Marneaus
hey, thanks guys, you've all offered good info so far.
so, as far as buying a new truck goes, what should i look for or ask about or whatever regarding the tranny if i am going to get an auto? anything in specific?
Old May 10, 2006 | 09:42 AM
Ram_Sport's Avatar
Ram_Sport
uh, what do you consider beating on it cause i dont want any troubles, i do have to get my "bands" adjusted according to DCX and there 100,000 mile letter they sent me, i get on it from time to time and WOT cause, ex. i aint gonna buy a gaming computer and just use it for word processing, get my drift, also i like to go through some trails and maybe a lil mud ya
Old May 10, 2006 | 02:04 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
my tranny didn't get its first lube job till over 120,000 miles and I have literaly beaten the hell out of it. Everythng from water half way up the doors mudding and hittin atleast 110mph monthly. I have also done alot of towing with it for work and things of that sort. I now have 252,000 miles on it and I am getting it rebuilt because I drove around on a bad tc for over 6 months and figured as long as its out might aswell rebuild it.
With any car it is a hit or miss kindof thing. You never realy know. It's like going to the casino and dropping $10,000 on 13 black.
