antenna removal
antenna removal
has anyone removed the antenna on a 2nd gen before? if so how did you go about doing it? i tried using vise grips on that "nut" and i didnt make any progress, i bought a replacement but the dodge dealer wants 120 bucks to do the replacement. ive been working on cars for quite some time and did my research. i found some tool that you can use to remove that nut but i didnt know if it was possible with just standard hand tools.
RE: antenna removal
ORIGINAL: HansonHVAC
I just had mine off and i just used a wrench and turned that nut counterclockwise came right off.
Are you trying to remove the antenna? Or the antenna mount? $120 sounds a bit steep to replace just the antenna [>:]
