Where to get Mopar PCM?
Old May 16, 2006 | 04:01 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Where to get Mopar PCM?
Anyone know where I can get a Mopar performance PCM for a '99. My usual contacts are telling me none are available from Mopar Chrysler, so I am hoping there are some resellers out there that might still have some in stock. Any ideas?
Old May 16, 2006 | 04:19 PM
V10's Avatar
V10
Default RE: Where to get Mopar PCM?
Try http://www.campbellenterprises.com/dodgeram.htm Campbell has the best price on the net assuming they are still in stock.
Does anyone know why you can't tow with the Mopar PCM?
Old May 16, 2006 | 06:33 PM
The Burning Rom's Avatar
The Burning Rom
Watch on ebay, if you can't get a new one from anywhere. They pop up on there often. They were discontinued a few years back. I was lucky enough to score two for my Ram last year.
An alternative would be to get a flash from here: http://www.bgchrysler.com/Service/Hi...b_g_flash.html I may look into a flash for my truck once I get the headers on and a cam (which is a year or two down the road).
Towing is not recommended due to the timing advance. There's a chance that you could experience severe knock/detonation under a heavy load. I've towed a 3500# car on an 18' trailer already with no issue...of course the V10 is a lot like a diesel...it takes a lot to make the motor work hard. I would never tow anything over 7000# or so though, without swapping the stock computer back in. If you ran a 180 (or 160) T-stat, you probably wouldn't have anything to worry about.
I'd also think the shift point raise would have a negative effect on towing as well. From 4800 to 5200 RPMs on the V8 PCMs. But from what I've read, it doesn't. [>:]
Old May 16, 2006 | 06:58 PM
mopowar's Avatar
mopowar
The shift points hit 52k at wot, so, unless you really nail it while towing, I wouldn't think you'd have anything to worry about there. They also do not recommend towing because of the potential to break drivetrain components. To smoothly apply torque to the drivetrain, the stock pcm pulls timing under heavy load/hard acceleration then puts it back as the truck comes up to speed. A performance pcm or flash does not do this. It just throws the motor's output right to it. If you are careful and go easy, I wouldn't think you'd have a problem towing, but, as The Burning Rom said if you try to pull to much you will get detonation.
Old May 16, 2006 | 07:23 PM
Silver_Dodge
Well, I only tow a small pop up camper that weighs at most about 2000lbs if that. I have had several conversations with B&G about the custom flash, just not sure about the inconveniece of having to mail them my PCM for a few days to get it flashed. Also, cost is a little higher, and the performance PCM for the 5.2 has almost as much timing advance as what they do in the custom flash, so results with it would be very close to what I would get with a flash.
I am also looking for a stock PCM that I can have as a spare for while mine is being flashed, if I decide to go that route.
With the Mopar PCM, I can always put my stock PCM back in when I tow.
Old May 16, 2006 | 07:38 PM
mopowar's Avatar
mopowar
I don't know about the Mopar pcm- never used one, but I have been very pleased with the B&G flash. I would say you're probably right though so long as the Mopar does not have torque management on it. If you do find a stock pcm, you may want to send them that one and keep yours. I sent them a pcm from a 2001 2500 to flash so it doesn't have to be an exact match.
Old May 16, 2006 | 07:44 PM
The Burning Rom
ORIGINAL: mopowar
Ah yes, I forgot...they also got rid of the torque management. [8D]
The TQ management on the early 3rd gen HEMIs is really bad [:'(]
Old May 16, 2006 | 07:53 PM
Silver_Dodge
So the Mopar PCM does not have torque management?
Old May 16, 2006 | 08:06 PM
mopowar's Avatar
mopowar
For our trucks...????. I have heard it does and that it doesn't. I think the guy at B&G says it doesn't, but then he is selling his deal. I have read in other forums that it does and that it doesn't. Who knows? I know the B&G flash gets rid of it.
Old May 16, 2006 | 08:45 PM
The Burning Rom
I know the B&G flash and the cam cal flash get rid of it.
I've never found any info that says the MP PCM doesn't have it. But I've also never felt the effects of it in my truck. It could be because of the PCM, or it could be because of the age of my truck. It's pre-electronic transmission. TM may have been something added with ODBII...or with the 46/47RE transmissions. [>:] I'm not sure when it was introduced, and I can't seem to find any info about it in my Powertrain Diagnostics Manual for my 94. [>:]
If it's there...it's very minimal. Not the horrible plague that it is on the 3rd Gen Rams [:'(]
