OFF ROAD COIL ?
Old May 17, 2006 | 06:54 PM
mavrik's Avatar
mavrik
Default OFF ROAD COIL ?
Anyone know the load rating of the 225AA coils used on off road rams......i pondering wether to get a set of them or the #037/#038 3/4 coils for my 1999 qc ram 4x4. I'm looking at the 3/4 b/c i will be putting a plow on the truck and i don't want a ton of drop in the front....any idea...thanks
Justin
Old May 17, 2006 | 07:13 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default RE: OFF ROAD COIL ?
Try this page. It tells you the load ratings for the different front springs on Rams. http://dodgeram.org/tech/specs/springs.htm
Old May 17, 2006 | 07:27 PM
The Burning Rom's Avatar
The Burning Rom
#39 spring on the driver side and a #38 on the passenger side are the plow package springs.
If you were putting on a heavy plow, like a Vee (I'm guessing you're not with a 1/2 ton) you'd want to use #48 on the passenger side and #49 on the driver side.
Old May 18, 2006 | 11:51 AM
mavrik's Avatar
mavrik
thanks for the info.....no info on the load rating of the 225AA coils? i was thinking of going #037's b/c i can get the height and they will be stiff and good for a plow but will be a tad less stiff than the #038's....what you guys think....i appreciate any input....
thanks
Justin
Old May 18, 2006 | 03:39 PM
The Burning Rom
ORIGINAL: mavrik
There doesn't appear to be any. I'd assume it's somewhere between the 3/4 ton coils and the 1/2 ton coils.
I'm not sure if you meant go with 2 #037s, but you may want to actually go with a #037 on the pass. side and #038 on the driver side (because of the driver, battery, gas tank, brake booster).
It will make a difference. I plowed with my Ramcharger for almost 16 years with just the stock springs in it, and it noticeably leans towards the driver side.
