ABS/Brake light sensor
Old May 19, 2006 | 10:35 AM
1500sport's Avatar
1500sport
Default ABS/Brake light sensor
I know this has been discussed many times, but my Dad has a 95 1500 4x4 5 speed and the abs/brake light on the dash stays on all the time but the speedo works fine. I thought from all the posts I've read the speedo usually dooesn't work right either and it is the sensor on the rear axle. Could this still be the case or is there something else to look for? Thanks in advance.
Old May 19, 2006 | 12:36 PM
smartobject's Avatar
smartobject
Default RE: ABS/Brake light sensor
I had the rear diff speed sensor go out, but along with that, my speedometer would not start working until around 20 mph. Then, then, the "kick-in" point started moving higher, so that it wouldn't work until 35 mph. So I replaced the sensor and the speedo worked fine. Since the speedo is working in your case, I would try other components -- check all the connections. I don't know anything about the ABS plungers, control modules, etc.
Old May 19, 2006 | 12:38 PM
Socha_62's Avatar
Socha_62
If its not the speed sensor (I'd replace that first though) it could be something with the ABS module.
Old May 20, 2006 | 11:35 AM
azffighter's Avatar
azffighter
I actually bought the sensor from rockauto.com and replaced the sensor on the back rear transfer case and the light went off and I've never had another problem.
Ken
Old Nov 18, 2007 | 10:33 AM
manlawn04's Avatar
manlawn04
how do you get the sensor out?? I have tried to pry (not hard) to no avail. If onyone know the secret to removing the stuborn sensor, please post or email me quickly,
email: cah1646@yahoo.com Appreciate it greatly
