transfer case fluid question
Old May 19, 2006 | 11:38 AM
shott8283's Avatar
shott8283
Default transfer case fluid question
I'm doing the routine fluid swaps in everything on the truck. Engine Tranny and Diff. I figured while I was in there I would swap the t-case fluid since I havn't changed it since I had the truck so who knows whats in there and how long its been in there for.
The book says to use DexronIII automatic fluid. Some websites say ATF+3. I am putting ATF+4 Syn in the tranny and I was wondering if I could do the same for the t-case. Or what fluid you guys use.
Old May 19, 2006 | 11:47 AM
DPR250R's Avatar
DPR250R
Default RE: transfer case fluid question
I am by no means an expert but I did my trans and transfer case about 2 years ago with Dexron III and both have been fine.
I drive mostly city and highway.
I only use 4WD in the snow... so not that often.
I do not take my truck off-road very much at all and am pretty gentle if i do.
Old May 19, 2006 | 12:12 PM
TPSDODGE's Avatar
TPSDODGE
i will find out for you when i go to work today..
Old May 19, 2006 | 12:18 PM
The Burning Rom's Avatar
The Burning Rom
ATF+3/+4...bascially whatever you put in your transmission
I miss the days when you could fill them with motor oil [>:]
Old May 19, 2006 | 12:37 PM
Socha_62's Avatar
Socha_62
I used ATF3 and its been probably a year. No problems!
If you have extra ATF4 its not gonna hurt anything
Old May 20, 2006 | 04:16 PM
badram1500's Avatar
badram1500
I've got dextron III in mine for now, pulling a 25' camper with no problems. Going to put the royal purple in it at the next change.
Old May 20, 2006 | 04:19 PM
shott8283's Avatar
shott8283
Thats what I am going to use is the extra ATF4 Syn that I bought.
One observation on the synthetics, good lord to they SMELL!! Changing the tranny fluid yesterday, that stuff straight reeked to high heaven
