3 Qs Headlights, oil change, brakes...
Old May 22, 2006 | 04:11 PM
nmason's Avatar
nmason
Default 3 Qs Headlights, oil change, brakes...
ok, ive been pissed at my headlights for a while now. i seem to have to replace them wayyy too much. every 3 months or so. and those ge nighthawks arent cheap is there anything i could do to prolong the life besides not using them?
also my brakes. i need new ones. front pads and rotors. any suggestion as to what i should put on? i want ceramic pads to help keep the wheels clean. they tend to turn brown with brakedust whilst commuting.
lastly, doing an oil change tomorrow. ive got the V6 in my truck. how much oil do i need?
thanks
Old May 22, 2006 | 05:01 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 3 Qs Headlights, oil change, brakes...
ORIGINAL: nmason
thanks
Try a different bulb. Maybe it's the nighthawks that are junk Check to make sure your capsules aren't loose.
Ceramic pads will wear on your rotors faster, and also tend to make more noise when braking.
IIRC, 4 qts. of oil with filter change.
Old May 22, 2006 | 08:21 PM
Socha_62's Avatar
Socha_62
Damn, my trucks 9 years and and it still has the factory bulbs in them...
Old May 23, 2006 | 01:17 AM
nmason's Avatar
nmason
yeah, not the bulbs. also used sylania, generic, and these ricer ones i got at the toronto indy. same deal on all of them. and everything seems nice and tight in there too.
Old May 23, 2006 | 04:49 AM
Chopper1's Avatar
Chopper1
Sounds like a loose connection/ground. Just replaced my first headlight couple of months ago.
