Shock question
Old May 23, 2006 | 12:54 AM
Gmanf's Avatar
Gmanf
Default Shock question
I am going to install the leveling kit in the front of my 2500 and wanted to know what shocks some of you with this done to your truck are using on the front.
Old May 23, 2006 | 01:22 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Shock question
A lot of people here run Rancho 5000 (or 9000) shocks.
BTW, you should remove that powerdyne throttle body spacer. It's not helping your fuel injected motor. In fact, it's probably hurting your performance
Old May 23, 2006 | 01:32 AM
Sehr916's Avatar
Sehr916
If you put a leveling kit do you need new shocks in the front? I am running Bilsteins but I don't think those are availible for the 3\4 ton
Old May 23, 2006 | 01:41 AM
The Burning Rom
ORIGINAL: Sehr916
I think that new shocks are only required if you level an off-road package equipped vehicle.
And yes, Bilsteins are available for 2500 & 3500 Rams.
Old May 23, 2006 | 04:43 AM
Chopper1's Avatar
Chopper1
Would not recomend the Rancho 5000's. They are very tight. I have them and forget setting your drink down. Have to take a drink of coffee between bumps in the road.
