PLEASE HELP motors is knocking? cant figure it out
I have ran into alot of the dodges that have the same exact problem" parts maneger at a NAPA store " see and hear alot. Dodge has a small pickup screen on there oil pump and over time that screen gets plugged. I bought my 2000 5.9 4x4 2 years ago and had a knocking in it and would loose oil presure at highway speed. From see ining and hearing from the shops and the dealer they told me that if i would flush the engine with of course there "engine flush" it would stop. Well i did the old school way and when i changed my oil i added one quart of trans fluid to my oil and drove it for 1000 miles and then changed it again. And did it one more time, the oil was black and thick both times,and havent had a problem since. My oil pressure runs 45-50 at highway speed and 35-40 at an idle. Trans fluid is a dang good cleaner and it will burn out of the engine so watch you oil level,in 1000 miles i maybe lost a half a quart and after cleaning the motor inside and puyying castol oil in it no noise and it dont even burn oil. oh and when i bought it it had 112,000 miles on it and now theres 138,000 on it
I know this is an older post. but its the best one that fits my problem. my 99 dak has started to make a knocking noise at idle when it warms up. when it's cold there is no noise. it started just after I brought it back out for the summer acouple weeks ago.
but when I rev it up pass 2000rpm it goes away. it sounds like a rod bearing to me. you cant really hear it when you above the engine, just underneath it. sounds like near the back of the motor in the oil pan.
I dont know how good it is to drive it like this so I brought out the 88 dak till I figure whats going on.
I posted in the dak section, but since there the same motors and I'll probly get a better reply here.
ORIGINAL: rico
Has anyone else done this?
i looks too tight to pull the pan down there. I dunno, I'll look at it more closer to see if I'll have room to pull it. if not, looks like I'll be pulling the motor to see where this knocking is comming from. I'm gonna try a mechanics stethiscope(spelling?) this weekend to see where its exactly comming from.
aslo when I rev it up and when the rpms are comming back down you can hear it rattle for a bit, which makes me think valve train.
but hopefully after this weekend I'll have a better idea where its comming from.
and I used to use tranny fluid in the oil all the time. it works pretty good. never used it on the 99, but in my 82 ram it worked wonders.
ORIGINAL: jonnymagnum
If you go to this effort, buy a Melling High Volume Pump. The high volume will give some additional life to your engine. For an exstra $25 you can but a new Melling screen if you want. The oil pan gasket should be re-uasable. Be extra careful putting the pump in and make sure it is 100% flush with the block when tightening the bolts. Failure to do this will cause the pump to crack and fail.
In the past (Pre MMO or SPecialty Engine flush days) I used the tranny fluid method and it does work great.
