Wierd problem
Old May 24, 2006 | 12:17 PM
mopowar's Avatar
mopowar
Default Wierd problem
This one has me stumped. When I switch between reverse and drive and step on the gas again the truck stumbles. It just seems to cut out for about 1/2 a second, then comes back fine. I'll back out of the driveway or a parking spot, put it in drive, apply the gas, and it will rev for a second, cut out for 1/2 second, then come back fine. It happens with light pedal or heavy pedal. It also happens if I am going forward, put it in reverse and apply the gas. I can stop, and apply the gas going in the same direction I was and it does not happen. No codes and the truck runs like a top otherwise. Any suggestions would be greatly appreciated.
Old May 24, 2006 | 04:43 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Wierd problem
Have you tried cleaning the TPS?
Did you check out the IAC?
Those are the two items that come to mind with a problem like this.
Old May 24, 2006 | 05:01 PM
mopowar's Avatar
mopowar
TPS is about 5k miles old. I'm putting an M1 on Friday so I'll clean the IAC, although it's not been all that long since I've done it. I really haven't done anything yet because I can't figure out where to start. Everything I can think to check would make it act that way all the time and not just when going from reverse to forward and visa versa.
Old May 24, 2006 | 07:56 PM
20dodgeram01's Avatar
20dodgeram01
dirty fuel filter?
Old May 24, 2006 | 08:03 PM
Sehr916's Avatar
Sehr916
Check the tranny fluid.
When I was working on the fluid and filter the other day I was low on fluid and I stupidly drove it with not enough fluid and it did that same thing
Old May 24, 2006 | 08:07 PM
mopowar's Avatar
mopowar
I put a fuel gauge on it. It reads 49 psi at key on and from 1k rpm up, but at idle the needle flickers. It goes down about 2 psi then back up. It moves back and forth like that real fast, maybe 5 times a second. Anyone know if this is normal?
I will check the fluid again. I just put a converter it in a few weeks ago and checked 3 times after. It was doing this before and after the TC change, but seems to be doing it more consistantly now.
