Intake gasket
Old May 28, 2006 | 02:53 AM
Darren's Avatar
Darren
Default Intake gasket
Hey guys I am in the middle of changing my intake and plenum gaskets on my 1999 dodge ram 318. How should I dress the gaskets? and while I have my fuel injectors off is there a way I can clean them? Thanks Darren
Old May 28, 2006 | 08:38 AM
Socha_62's Avatar
Socha_62
Default RE: Intake gasket
You can soak the injectors in cleaner if you want.
Also for the gasket you can pick up some Hi-Tac and spray them lightl with it. It makes gaskets tackey. The key is to make sure you get all the old gaskets off without damaging the surface. Also use some RTV on the smaller gaskets that go on the front and rear. Not alot, but on each end/corner just add a dab!
