6 speed trans
Old May 30, 2006 | 10:27 PM
TPSDODGE's Avatar
TPSDODGE
Default 6 speed trans
so i am going to put a six speed trans out of a srt10 in my 95 1500 with a 5.2 has any body else tried this?
Old May 30, 2006 | 11:13 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 6 speed trans
I know there's 1 guy that did it with the V10, but I don't know of anyone that's done it with the 318/360. And the guy that did it with the V10 didn't seem to have a lot of luck with it. He blew 2 or 3 of them up before switching back to the auto.
You're going to need to adapt the bellhousing...because it's definitely not going to bolt up [>:] Aside from that, I couldn't tell you what else you're going to run into.
Old May 30, 2006 | 11:39 PM
mopowar's Avatar
mopowar
ORIGINAL: The Burning Rom
How determined was that guy[sm=alcoholic.gif]
If it doesn't bolt up, that should be enough. Unless of course this is not your DD, and you have a couple of screamin' kids in the house. Then I would say, "make it work".
Old May 31, 2006 | 08:19 AM
TPSDODGE's Avatar
TPSDODGE
well my my trans tech from work(dealer) said the bell housing and what not is the same... so were talking about flywheel, clutch, custom drive shaft, mount. Not that much work for an extra grear[&:]
Old May 31, 2006 | 10:09 AM
HankL's Avatar
HankL
The heavy duty New Venture 5600 six speed manual transmission should also be considered for a swap. This New Venture Gear built trans has a great rep and was used behind the Cummins HO in Rams.
Note that the T56 used in the SRT10 has different ratios than T56's used behind GM products.
The tall 0.50 overdrive is a useful setting in combination with the ratios of gears 1-2-3.
Note that with the 300/Magnum vehicles using W5A580 Mercedes autos behind the 5.7 Hemi there is now a Chrysler bell housing to adapt to those too.
Note that the new ML series SUV has a 7 speed auto.
archived info;
For those not aware, the venerable New Venture (now once again New
Process) NV5600 6 speed manual will be replaced sometime during the 2004
model year by the Getrag G56. The two key aspects of the G56 are:
- lower overall weight thanks to an aluminum case (compared to the
incredibly heavy iron case of the NV5600)
- higher power input
The ratios of the new G56 are a tad lower than the 5600 as well - the
5600 number is first, then the G56:
1st - 5.63 - 6.29
2nd - 3.38 - 3.48
3rd - 2.04 - 2.10
4th - 1.39 - 1.38
5th - 1.00 - 1.00
6th - 0.73 - 0.79
Rev - 5.63 - 5.74
This new 6 speed will also replace the NV4500HD used with the Hemi in
the 2500, 3500, and Power Wagon models.
The 1500 will also gain a Getrag 6 speed manual, this is the model 238
used with the 3.7 V6 and 4.7 V8 (no manual offered with the 1500 Hemi)
1st - 4.23
2nd - 2.53
3rd - 1.67
4th - 1.23
5th - 1.00
6th - 0.79
Rev - 3.84Transmission:
NV4500/NV4500HD - Manual, Five-Speed Overdrive
Availability: NV4500 - standard with 5.7-liter V-8 and 8.0-liter V-10 engines
NV 4500 HD - standard with 5.9-liter standard output I-6 diesel
Description: Synchronized in all gears
Gear Ratios:
1st: 5.61
2nd: 3.04
3rd: 1.67
4th: 1.00
5th: 0.75
Reverse: 5.04
Overall Top Gear Ratio: 2.80 with 3.73 axle ratio and 3.07 with 4.10 axle
ratio
Transmission: NV5600 - Manual, Six-Speed Overdrive
Availability: Standard with 5.9-liter high-output I-6 diesel engine
Gear Ratios:
1st: 5.63
2nd: 3.38
3rd: 2.04
4th: 1.39
5th: 1.00
6th: 0.73
Reverse: 5.63
Overall Top Gear Ratio: 2.72 with 3.73 axle and 2.99 with 4.10 axle
Transmission: 545RFE - Automatic Five-Speed
Availability: Optional with 5.7-liter engines
Description: Three planetary gear sets, one overrunning clutch, full
electronic control, electronically controlled converter clutch
Gear Ratios:
1st: 3.00
2nd: 1.67 - upshift; 1.50 kick-down
3rd: 1.00
4th: 0.75
5th: 0.67
Overall Top Gear 2.50 with 3.73 axle and 2.63 with 4.10 axle
Transmission: 47RE/48RE - Automatic, Four-Speed Overdrive
Availability: 47RE - Optional with 8.0-liter V-10 and standard-output Cummins
diesel engine
48RE - Optional with 8.0-liter V-10 and standard-output Cummins diesel engine
Description: Hydraulic control, electronically controlled governor overdrive,
overdrive lockout and converter clutch
Gear Ratios:
1st: 2.45
2nd: 1.45
3rd: 1.00
4th: 0.69
Overall Top Gear Ratio: 2.57 with 3.73 axle ratio and 2.82 with 4.10 axle
ratio
Transfer cases: NV271/NV273
Availability: NV271 - Standard 4WD ST
NV273 - Standard 4WD SLT Plus
Type: Part Time
Operating Modes: 2WD; 4WD High, Locked; Neutral;
4WD Low, Locked
Shift Mechanism: NV271 - manual, NV273 - electric
Low-Range Ratio: 2.72
Center Differential: None
Dave Fritz's table at:
http://www.dodgeram.org/tech/transmission/4xrh.htm
Mercedes-Benz
ML230 ML320 ML430 ML55 ML270CDI ML270CDI
5 sp manual 5 sp auto 5 sp auto 5 sp auto 5 sp auto 6 sp manual type
GL76/29B-5 W 5A 330 W5A 580 W5A 580 W5A 580 NSG 370 * max. torque
input 202 lb / ft
275 Nm
242 lb / ft
330 Nm
426 lb / ft
580 Nm
426 lb / ft
580 Nm
426 lb / ft
580 Nm
272 lb / ft
370 Nm
1st 3.856 :1 3.951 :1 3.595 :1 3.595 :1 3.595 :1 5.014 :1 2nd 2.183 :1
2.423 :1 2.186 :1 2.186 :1 2.186 :1 2.831 :1 3rd 1.376 :1 1.486 :1 1.405 :1
1.405 :1 1.405 :1 1.789 :1 4th 1.000 :1 1.000 :1 1.000 :1 1.000 :1 1.000
:1 1.256 :1 5th 0.799 :1 0.833 :1 0.831 :1 0.831 :1 0.831 :1 1.000 :1 6th
0.828 :1 reverse 4.218 :1 3.147 :1 3.167 :1 3.167 :1 3.167 :1 4.569 :1
reverse in 4low 1.930 :1 1.926 :1 1.926 :1 1.926 :1 converter ratio
1.85 :1 1.80 :1 1.80 :1 1.80 :1 weight 31.8 kg 76 kg 80 kg 80 kg
80 kg 40.5 kg previous version W 5A 300 W5A 400
Old May 31, 2006 | 08:00 PM
The Burning Rom
ORIGINAL: TPSDODGE
You were given bad information The pattern LOOKS similar, but it's not. The 318/360 have the same bellhousing pattern that they've had for YEARS. From 2003 all the way back to the 60s. The new 5.7L HEMI in the 3rd gen Rams shares this pattern. [8D] BUT, the V10 (iron & aluminum) and the Cummins have a completely different pattern. Not a small block...not a big block...their own special thing. So no...it's not the same.
For that same reason, the NV5600 would not work without an adapter though it would probably be a better choice for a transmission...there's more of them floating around.
Old Mar 31, 2020 | 11:17 PM
Skylor Brothers's Avatar
Skylor Brothers
Default Input shaft
you'd also need a different input shaft for the 360/318, the cummins and v10 have different input shafts and bellhousing patterns than the small blocks, it would be friggin sweet to have a nv5600 behind a 5.9 magnum.
Old Apr 1, 2020 | 07:11 AM
Please check dates on thread before you hit the reply button. This thread is 14 years old........ it's almost old enough to drive itself.
