sway bar
Old Jan 12, 2013 | 11:51 PM
  #21
Jjgerhart's Avatar
Jjgerhart
Working on it now didnt have a photobucket
Old Jan 12, 2013 | 11:58 PM
  #22
Jjgerhart's Avatar
Jjgerhart
Not sure if this will work either. not entirely sure how to post a picture on here yet....
http://m1301.photobucket.com/albums/Jjgerhart?newest=1
Old Jan 13, 2013 | 07:53 AM
  #23
Those worked.
Old Jan 13, 2013 | 10:57 AM
  #24
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yeah TJ discos would work. I almost did the JKS ones...but the coin for 'em didn't meet my fancy.
Good on ya for fabbing your own up!! Need more fab-monkey's around here!!
Here's your pics here for easy viewing. Looks like the album link used the "Mobile Version" so I guess you are posting from phone? Getting to fuller images see the "View Full Website Link" will bring you to larger images and running mouse cursor over enlarges with a choice of "links" below. Click once on the one that says IMG Code, then CTRL-V for pasting here:
It appears you'll be bagging the bushings and links. What will be your method to hold up the sway bar?
Old Jan 13, 2013 | 01:38 PM
  #25
Jjgerhart's Avatar
Jjgerhart
the sway bar mounts in the factory location. I also used Factory Hardware. I also set it up to use factory bushings and washers. the bottom is just a 5 eighths heim joint. then the whole that it mounts to on the axle I jus drilled out to 5/8 and that is where I used a tractor hitch disconnect. I will try and post pictures later today of the whole thing installed on my 01 RAM
Old Jan 13, 2013 | 01:40 PM
  #26
Jjgerhart's Avatar
Jjgerhart
thanks for posting this so everyone can see, using a phone kinda sucks for this.
Old Jan 13, 2013 | 06:23 PM
  #27
Aubrey's Avatar
Aubrey
Years back I built custom ones with rod-ends and they worked fine. After doing some later suspension work I took the bar off for a while and never got around to putting it back on.
Old Jan 13, 2013 | 09:17 PM
  #28
Jjgerhart's Avatar
Jjgerhart
Have new pics in my photobucket
Old Jan 13, 2013 | 11:45 PM
  #29
Wh1t3NuKle's Avatar
Wh1t3NuKle
Your welcome. You'll be getting on a PC at some point b/c this is last time I'll put the pics up for ya for immediate viewing. lol
I don't blame ya. Wielding that thing back up there is a PITA...post
Old Jan 14, 2013 | 12:56 AM
  #30
Jjgerhart's Avatar
Jjgerhart
Thanks again lol
