99 Ram 318: Towing Power
Old Jun 7, 2006 | 02:39 AM
Tempsho's Avatar
Tempsho
Default 99 Ram 318: Towing Power
I have a 1999 Dodge Ram 4x4 ext cab short box with a 318 and a 5 speed. I bought myself a 7'x14' V-Nose H&H enclosed trailer, and I was wondering what’s the safe towing capacity of this truck? It came with a factory installed hitch (I think class 4) and the factory 7 pin harness. (I also installed an electronic brake controller)
Anywho, the trailer empty is 2500 lbs, and i'll probably be loading it up another 1500 lbs or so for a total of about 4-4500 lbs.
I will be traveling about 700 miles (1100 km's) straight one way to my final destination, just wondering if i'll be alright or not. I have 285/75R16 tires with a 3.55 gear ratio.
Of course i'll only use 4th gear, and limit myself to about 90-95 KM/H. Anything I should do or look out for? Thanks guys
Old Jun 7, 2006 | 07:43 AM
Dodgy Style's Avatar
Dodgy Style
Default RE: 99 Ram 318: Towing Power
dude your truck will do fine with that trailer .I think you max weight is about 6500 to 7000 lbs.
I have the same truck but with a 360 auto and I pull a 7000 lbs 29 ft travel trailer and a 19 ft boat and I do fine
[IMG]local://upfiles/15130/769275F7FC0E4350A211BDEC37024DDF.jpg[/IMG]
[IMG]local://upfiles/15130/5DCDD006F54F41C9A9D9CA468CFA7584.jpg[/IMG]
Old Jun 7, 2006 | 10:11 PM
cableguy's Avatar
cableguy
LIke Dodgy said, you'll be fine. Your weights aren't outof whack, plus you have the brake controller.
