vacuum lines UPDATE LOOK @ MY PICS
Old Jun 7, 2006 | 05:44 AM
focushere's Avatar
focushere
Default vacuum lines UPDATE LOOK @ MY PICS
i have a 97 5.9 360 O.E. can some of you guys take some pictures to help me with the vaccum lines? i know i hooked some up wrong
(i know there is a diagram on the truck )
Here are some pics i snaped let me know if there is any questions
What is this deal with two plugs for vacumm line called
elec. tape is temp fix lol
Old Jun 7, 2006 | 11:27 PM
focushere's Avatar
focushere
Default RE: vacuum lines
come on someone help me out and snap some pics for me
Old Jun 8, 2006 | 10:44 AM
ASH's Avatar
ASH
What particular part of the truck do pictures of? I'm assuming the engine compartment. I could probably get some pictures today. Check in my gallery though, I do have some pictures of of my engine compartment in there, but not sure if it will help.
Old Jun 8, 2006 | 11:51 AM
focushere's Avatar
focushere
i would like some off the right side like pvc and the left side of the manifold
Old Jun 8, 2006 | 12:28 PM
ASH's Avatar
ASH
Let me know if you need more. Right side.
[IMG]local://upfiles/26321/47629BAD97EA4BC686AC47413AF25683.jpg[/IMG]
ASH's Avatar
ASH
Left side.
Old Jun 8, 2006 | 05:54 PM
focushere's Avatar
focushere
bump for pics
Old Jun 9, 2006 | 10:58 AM
ASH's Avatar
ASH
Do you know if your truck has the California emissions? I was studying the hoses and can't figure out where they are going. My truck has the light duty, non-California emissions 360 engine, so most of the vacuum lines are pretty simple. The vacuum for the PCV valve goes right into the throttle body, then the breather on the left sige of the engine goes into the air filter housing. I don't have any of the T's and connections that you have. Trace them and see if they lead to any other components. The lines don't look like they came from factory, due to they way they stick up the the air on the right side. Sorry, but its hard to help from a distance.
Old Jun 9, 2006 | 02:23 PM
smartobject's Avatar
smartobject
Just a thought -- I don't have a Haynes manual for my '99 5.2L -- but I use one for a 1990 Spirit. When my vacuum lines were corroded and broken (on the Spirit), I used the diagrams / charts in the manual there. They worked great.
I don't know if they would have the same charts, but you can thumb through one at a parts store and see. If you like what you see, they're under $20-ish I think.
They're not photos, but line-drawings. Sometimes this type of drawing makes more sense than a photo.
