Tapping/Knocking underside
Old Jun 8, 2006 | 10:45 PM
East_TN_EMC's Avatar
East_TN_EMC
Default Tapping/Knocking underside
Hello, I am a long-time reader but first time poster.
I have a 2001 Ram 1500 5.9L gas with auto tranny.
I have a tapping/knocking sound coming from the underside of the truck. I can also feel under the gas/brake pedal area. It feels like someone is under the truck tapping on the frame rail with a wooden hammer handle. It seems to do this both while the truck is sitting in park and while driving down the road, but it does not do it constantly.
I have been under the truck while it was doing it, and it seems to be localized around the back of the oilpan, the bellhousing or the front of the tranny, but I could not trace it closer than that.
Anyone run into this or have any ideas?
Thanks
Old Jun 8, 2006 | 10:49 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Tapping/Knocking underside
Sounds like the torque converter to me [>:]
Old Jun 9, 2006 | 12:02 AM
theshocker's Avatar
theshocker
Mine does the same thing every once in a while. Still can't figure out what it is. The noise is completly random, no rythym to it at all make it hard to pinpoint![:@]
Old Jun 9, 2006 | 12:20 AM
fiveliterbtr's Avatar
fiveliterbtr
SUBJECT:
Tranmission Shifter Linkage Rattle
OVERVIEW:
This bulletin involves installing a spring on the transmission linkage
MODELS:
2000 - 2001 (BR/BE) Ram Truck
SYMPTOM/CONDITION:
A rattling or knocking sound may be present at the driver side floor pan area when the
engine is idling.
DIAGNOSIS:
With the engine at idle, listen for a rattling or knocking sound coming from the driver side
floor pan area. If the sound can be heard or a if a vibration can be felt in the floor pan,
perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 05101832AA Spring
AR 04318063 Grease
REPAIR PROCEDURE:
1. Place the transmission in park.
2. Raise the vehicle on a hoist.
3. Pry the gear shift rod vertical link adjuster block from the torque shaft lever(Fig. 1).
Inspect the plastic grommet. If any damage is present, replace the grommet.
NUMBER: 21-001-03
GROUP: Transmission
DATE: January 31, 2003
Fig. 1 TRANSMISSION LINKAGE
1 - Torque Shaft
2 - Spring
4. Remove the three screws that attach the torque shaft to the floor pan support.
5. Remove the torque shaft by prying the shaft out of the plastic grommet on the
transmission side. Inspect the plastic grommet for any signs of damage and replace as
required.
6. Clean the torque shaft and grommets and apply a coating of grease, p/n 04318063 or
equivalent, to the torque shaft in the area that the grommets and spring will sit.
7. Instal the new spring, p/n 05101852AA, over the shaft as shown(Fig. 1) and insert the
end of the shaft into the plastic grommet.
8. Install the toque shaft attaching screws and tighten them to 30 Nm (300 in. lb.).
9. Install the gear shift rod vertical link into the grommet.
10. Lower the vehicle and ensure that the gear shift link is adjusted properly and that the
gear indicator (PRNDL) on the instrument panel is reading correctly. Adjust the shift
linkage and/or the indicator cable as required.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation
No:
Description Amount
21-75-30-91 Transmission Linkage - Install Spring 0.3 hrs.
FAILURE CODE:
68 Noisy
That was my odd tapping noise.
Old Jun 9, 2006 | 12:26 AM
The Burning Rom
Oh yeah..I forgot about that recall [>:]
Old Jun 9, 2006 | 12:34 AM
fiveliterbtr
Heh, it was the weirdist noise...couldn't pinpoint it, just drivers floor area, near the pedals...without that TSB, I'd still be wondering wtf it was 'cause I sure didn't see anything obvious under there.
Old Jun 10, 2006 | 08:12 PM
jb0578's Avatar
jb0578
This could be noise from loose ceramic pieces rattling in the catalytic converter. There is a recall on the converters if your vehicle meets their age and mileage parameters. I have the same problem with a 98 1500 and the catalytic converter has to be replaced but as this does not effect anything, I am in no hurry.
Old Jun 10, 2006 | 08:22 PM
Sehr916's Avatar
Sehr916
I have that same noise and was thinking it was that TSB. Where did ya'll get the parts to fix it. I tried makeitmopar but they did not have all of them. Thanks
Old Jun 11, 2006 | 03:21 AM
fiveliterbtr
ORIGINAL: Sehr916
Got it from the dealer, since I work at an aftermarket shop, it was @ cost Sorry I can't get it for you at the same price.
