any way to increase volts from 0.6 to 12?
Old Jun 9, 2006 | 07:33 PM
radwebster's Avatar
radwebster
Default any way to increase volts from 0.6 to 12?
my parking light flash output from my keyless entry box is only putting out like 0.6 volts. it needs to be around 12V to trigger the relay. anything i can add to raise the output volts?
Old Jun 12, 2006 | 10:57 PM
hukares's Avatar
hukares
Default RE: any way to increase volts from 0.6 to 12?
Yes, but if the voltage is low then something is broke. You should fix the broken part. Otherwise, you could use another relay with a lower voltage coil or use a transistor (several likely). For the hell of it you could even use vacuum tubes. You would have all kinds of bling with vacuum tubes glowing under your dash.
Old Jun 12, 2006 | 11:32 PM
shott8283's Avatar
shott8283
ORIGINAL: hukares
confused me
you got a short some where... shorts are bitches to shoot out in relays and complicated circuits...
Old Jun 13, 2006 | 05:17 AM
radwebster's Avatar
radwebster
yea, it used to work correctly then one day it just stopped. i got the whole unit for free, so i dont want to buy another box.
i'm looking for the cheapest setup i could pop in there to make the lights work. any of you electricla guys have any good ideas?
