Misfire on #5
Old Jun 11, 2006 | 12:29 AM
Gatorbate88's Avatar
Gatorbate88
Default Misfire on #5
Well sorry to say the problem still exists! I ran the Sea Foam through per the directions and the light went away. Ran fine for about a week and then the light came back. The hesitation seems a little better, but the rough idle and gas mileage are killing me. Any info would be greatly appreciated!!
Thanks,
Sgt. Gaylor
Old Jun 11, 2006 | 03:48 AM
556fmj's Avatar
556fmj
Default RE: Misfire on #5
have you checked the heads? I bet you have a cracked exhaust seat in #5... also, did you yank the injectors to see if #5 had some crap on the inlet? You could try swapping injectors into different cylinders and see if the miss moves with the injectors... just mark them first.
SGT Dorey
Old Jun 11, 2006 | 04:40 AM
Dodge4x4810's Avatar
Dodge4x4810
If you have already done a full tune up, i would check the heads, could be a burnt valve.
Old Jun 11, 2006 | 12:24 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: 556fmj
SGT Dorey
There is no need to swap the injectors. The easy way to see if an injector is plugged is to start the truck and let it idle. Then, unplug the connector at the suspected injector. If the idle doesn't change, then that injector is either plugged, not receiving a pulse, or is inoperable. It is very rare for an injector to no longer function.
Old Jun 12, 2006 | 03:51 AM
556fmj's Avatar
556fmj
ahhh.... so true! you are wise! Yeah, just do that... so much easier... why didn't I think of that?!?!?!
Old Jun 12, 2006 | 12:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: 556fmj
I'm not wise. I'm passing along knowledge I have acquired. Check out my thread where I broke open my engine. I had three out of five injectors clogged. https://dodgeforum.com/m_393897/tm.htm
Old Jun 12, 2006 | 07:27 PM
pirranah's Avatar
pirranah
also you can feel the tick if it's getting a pulse. my #8 was clogged, i hear that they are prone to get gunk built up towards the back of the rail, then when you throw some cleaner in it it breaks loose and cloggs the injectors. when we changed my injector we pulled the rail off and cleaned it real good.
