1/2 to 3/4 ton question
Old Jun 12, 2006 | 03:12 PM
apl2964's Avatar
apl2964
Default 1/2 to 3/4 ton question
I just put a custom steel bumper\grill guard and a 12000 pound ramsey winch. My 1/2 ton springs arnt doing the job anymore. Has anyone tried to put 3/4 ton coils on a a 1/2 ton. It looks like it should fit right in and add about 3 " of lift. The look like the same diamiter over all. Just a thicker spring. What do you all think. or is there something else i can do. Thanks
Old Jun 12, 2006 | 03:26 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 1/2 to 3/4 ton question
Several people have done that. I don't think you'll see 3" of lift though unless you go with the Diesel/V10 springs. The ride will definitely be harsher.
Old Jun 12, 2006 | 03:30 PM
Tani1500's Avatar
Tani1500
with the 2500 springs you would normally get around 1-1/2 to 2 inches of lift but with the bumper and winch it should put you right around stock height.
Old Jun 12, 2006 | 03:38 PM
apl2964's Avatar
apl2964
is dodge the only place you can get them from?
Old Jun 12, 2006 | 04:09 PM
mavrik's Avatar
mavrik
you can get them aftermarket thru trailmaster or superlift or such.....the ones at dodge are 118 dollars a piece
Old Jun 12, 2006 | 04:12 PM
apl2964's Avatar
apl2964
How big should i go. The winch and bumber must be around 500 ot 600 lbs total. Should i got 38#39# or the big 47#48#
Old Jun 12, 2006 | 06:18 PM
apl2964's Avatar
apl2964
i think ill go with the bigger 47-48 spring set up. Now for all you guys that have done this. is there different springs from dodge. My dealer says there is different springs. So do i order for the same year truck or how do i go about it thanks.
