Voltage going into crank sensor (dim light)
Old Jun 15, 2006 | 01:03 AM
kkfixes's Avatar
kkfixes
Default Voltage going into crank sensor (dim light)
We pulled the plug on the crank sensor and the test light lit but it was a dim light. How much voltage is entering the crank sensor? Should the light be bright? thanks.
Old Jun 15, 2006 | 01:52 AM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: Voltage going into crank sensor (dim light)
Depending on the year, either 8v or 5v, iirc...early/mid 90's used 8v, late 90's and newer use 5v...a 12v test light should be fairly bright, however, I strongly recommend a DVOM...test light diag. is definately NOT accurate.
